[Paid] Lightweight LMS Plugin for Discourse
csandstedt is seeking a developer to create a lightweight LMS plugin for Discourse, allowing users to progress through courses via topics with features like a progress bar and thumbnail previews, with a budget of $2,000 and a February 2023 deadline. angus offers a pre-built solution, “Discourse Learning Management,” which includes unit tests and an importer system, but notes that building such a plugin from scratch would likely cost at least $5,000 due to development and maintenance needs. pfaffman supports angus’s recommendation, citing trust in his work and estimates. Ahmed_Gagan also expresses interest in the project via PM.
I’m looking for someone to develop a lightweight learning management system for Discourse. Ideally, the plugin would allow me to have certain categories behave like an LMS where the user could progress through a series of courses (topics). Once they view a topic, there would be a button to navigate to the next topic. The topics would still behave like normal Discourse topics where users could discuss the topic. Since this is for an existing community, the plugin will not require all categories to be treated as courses, only selected categories.
Nice to haves would be a progress bar to show how much of the course has been completed. it would also be nice to have a thumbnail preview of the next course to let the user know what is coming up next.
I would like this to go live in February 2023 if possible.
My budget for this feature is $2,000.
I’m interested in this. I started using Discourse when I was a college professor and used Discourse to teach my classes. I used custom badges and even had a script that would pull my :hearts: from topics with certain tags and then push the results into the gradebook of the LMS that the university wass using.
Hi @csandstedt
I am interested to take this up, sending you a PM
I’ve actually already built pretty much exactly what you’ve describing :slight_smile: (with a few other features as well). It’s currently a private plugin called “Discourse Learning Management”. This is what it looks like.
The plugin is covered in “unit tests” (i.e. it’s robust). It also has an “importer” system that allows you to import course content from remote sources.
The content you’re seeing in the screenshots is imported from here.
https://github.com/pavilionedu/discourse-theme-introduction
If you’re interested in using it / adapting it to your needs you can PM me and we can discuss what changes you might need and what kind of relationship we’d have.
To build this properly from scratch this budget is probably too low. You may get someone willing to attempt it for this budget however the end result may not be want you’re hoping for. To build just your feature-set from scratch (i.e. without some of the additional features we’ve added) my initial estimate would be a minimum of $5000 USD.
You’re also going to run into the issue of support and maintenance. Any LMS plugin for Discourse, no matter how “lightweight” will involve modifications which need to be maintained over time.
I forgot about that! @csandstedt, I’ve seen this plugin in action and recommend it. And I trust Angus’s estimates, so I recommend you check with him to see what you can work out.
