On the beta branch, when attempting to create a POST on behalf of a user, I use the API and provide the username as the api_username. Because of the way I’m managing users, the user may not exist in Discourse at this time and I’d like to be able to respond to that exception by creating the user. It would be useful if the error had enough context to determine that this case occurred, but instead, it’s raising a Discourse::InvalidAccess and the server is returning a 500.
I can work around this, but it would be nice if the server responded with something in the 4xx range and enough information to determine the cause of the issue.
Just curious, is there an issue or something else I can follow related to this bug? I have a bit of code to work around it that I’d like to rip out once I know that I can
Thanks for the reply. In my tests, it would reply with a 500 with no
response body. It’s impossible to know the reason for the failure in that
case. I would think something in the 4xx range with some information
indicating the cause of the error (a username that does not exist) would be
more helpful and appropriate, no?
Here’s an example curl command with sensitive data stripped out:
curl -X POST -H "Content-Type: application/x-www-form-urlencoded" -d 'raw=demo of failing post on behalf of non-existent api-user&title=herp derp jerp' "<my_discourse_instance>/posts?api_key=<valid_api_key>&api_username=<nonexistent_username>" -i
