Passing through rel=0 on YouTube embeddings
Hello there,
I see we pass through width and height on YouTube embeddings. Any chance we can also get the rel=0 parameter through, so that one may disable suggested videos at the end of the linked video? The previous suggestion early last year didn’t seem to get much traction, but it seems like a good one and in line with the idea of keeping things on topic (the suggestions are often pretty random). I’d even argue that it should be the default, but at least passing through would be great.
Other good candidates are start and end, which allow controlling what section of the video linked to is actually played. Seems pretty sensible to support that too.
Perhaps someone should go through the supported parameters and see if anything else is worth adding for the context of Discourse.
Thanks!
7 „Gefällt mir“
The code you want is here: onebox/lib/onebox/engine/youtube_onebox.rb at main · discourse/onebox · GitHub
start & end are already supported.
8 „Gefällt mir“
Thanks. I’m tempted to just patch it to include rel=0 at all times in our distribution, as the whole point of embedding a video in a topic is precisely to let people stay in context while interacting with the conversation in the topic.
3 „Gefällt mir“
@techAPJ low priority can you make sure this parameter survives when passed through on our end?
2 „Gefällt mir“
Added support for rel=0 via:
https://github.com/discourse/onebox/commit/734c5eef1e370e39f9624da8bb1534d114f4cdf6
Note that YouTube changed the behaviour for rel parameter since September 25, 2018:
After the change, you will not be able to disable related videos. Instead, if the rel parameter is set to 0 , related videos will come from the same channel as the video that was just played.
7 „Gefällt mir“
