Password hash algorithm
I’m looking to be able to use the stored password hashes from discourse in a htpassword file for another app.
What password hashing algorithm does discourse use?
Sorry if I’m misunderstanding, but are you saying you want to effectively copy Discourse’s hashing algorithm to your own app so you can match the hashes your app generates against those stored by Discourse? Wouldn’t this require you to regularly sync the passwords from Discourse to your htpasswd file, handle salts that Discourse may or may not have now or in the future, and keep your implementation of the hashing algorithm in sync with Discourse’s algorithm forever?
Again, sorry if I’m completely misunderstanding, but I had to ask for clarification for my own curiosity.
Just for checking that a user name password is valid.
A user supplies a username and password. We check that the supplied password is valid according to the hash from discourse. We won’t be generating any hashes.
By “generates” I didn’t mean to store, but to validate the password is correct.
I wonder if Discourse has SSO in the opposite direction so that people can sign into other apps using Discourse directly.
Yes, discourse is able to be authoritative for sign-in and this is the correct path @csmu - Attempting to duplicate the hashing method would mean your sign-in method will break every time it changes.
It also wouldn’t account for users who don’t have a local password.
If you’re unwilling or unable to read the source to find the answer to your stated question, it might be best to take a step back and describe what problem you’re trying to solve.
I am able to read the source once I find it. I went looking through the source - for user.password - and I concentrated mainly on
the user_controller. Nothing jumped out at me. I’d appreciate any pointers on where to look.
What would work for me for is to be able to validate a user / password through discourse without adding in a sso signin / login. Maybe through the api or a direct call to some ruby code.
Oh. Yeah. Rails only makes sense after you know where stuff is. Here’s this
But I still recommend backing up and describing the problem rather than starting with your solution.
Thanks Jay -
After reading
 def confirm_password?(password)
    return false unless password_hash && salt
    self.password_hash == hash_password(password, salt)
in user.rb
the following works for straight ruby validation
user = User.find_by_email('some.email.address')
user.confirm_password?'valid-password'
=> true
I was experimenting with a .htaccess file for a server and I was looking for a way to validate a username / password through discourse for that server without knowing the passwords to generate the .htaccess file. The SSO approach is better and knowing how to validate a user name / password without using SSO will be useful for me.
안녕하세요,
로컬 로그인에 사용되는 비밀번호 해시 함수 및 관련 매개변수(해시 길이, 솔트, 실제 사용된 라이브러리 이름)에 대해 알고 싶습니다. 이전에 언급된 Ruby 파일을 살펴봐도 도움이 되지 않았습니다. 이 정보는 규정 준수(GPDR 및 일반적인 시스템 보안 분야의 모범 사례)를 위해 문서화에 필요합니다.
수정: 여기서 답변을 찾았습니다: Export password hashes in the PHC format → discourse/docs/SECURITY.md at main · discourse/discourse · GitHub
