PDF-ondersteuning in Discourse AI
:bookmark: This guide explains how to implement and use PDF processing capabilities within discourse-ai, including both basic text extraction and enhanced processing with LLM assistance.
:person_raising_hand: Required user level: Administrator
Summary
The discourse-ai plugin supports PDF processing for RAG (Retrieval-Augmented Generation) in two distinct modes:
  1. Basic text extraction
  2. Enhanced processing with LLM analysis
This mode provides fundamental PDF processing capabilities:
  • Extracts text content using the pdf-reader gem
  • Supports files up to 100MB
  • Works immediately after plugin installation
  • Processes text-only content (ignores visual elements)
Enhanced processing with LLM improvements
:information_source: This mode requires specific configuration and provides more advanced capabilities.
Requirements:
  • Enterprise plan subscription or self-hosted Discourse
  • ImageMagick with Ghostscript support installed in container
  • ai_rag_images_enabled site setting enabled (hidden — must be set via Rails console)
  • A RAG LLM model configured on the AI agent or tool
Capabilities:
  • Interprets images, charts, and diagrams
  • Provides context from visual elements
  • Processes PDFs page by page
  • Maintains the 100MB file size limit
  • Enables image file uploads (png, jpg, jpeg) for RAG indexing via LLM-based text extraction
Implementation details
Processing specifications
  • Page processing resolution: 300 DPI
  • Per-page image conversion timeout: 30 seconds
  • Automatic cleanup of temporary files
  • Full integration with RAG document embeddings
Processing workflow
  1. PDF upload and validation
  2. Content extraction (basic or enhanced mode)
  3. Text chunking with configurable overlap
  4. Chunk embedding and storage
  5. Progress tracking via MessageBus
Limitations
:warning: Be aware of these constraints when implementing PDF processing:
  • File size restrictions:
    • 100MB for existing PDF processing
    • 20MB for new admin interface uploads
  • Enhanced mode requires additional system resources
  • Complex PDF layouts may not be perfectly interpreted
  • Enhanced processing increases processing time significantly
See also:
This is really amazing news. Thanks team! Can’t wait for the enhanced processing to be finished. That’s gonna be critical for feeding LLMs research papers.
Also, is there any plan to allow doing RAG “chat-with-your-PDFs” by uploading PDFs in an AI bot PM or in a topic/post and mentioning the bot?
@sam Can you provide simple video to explain this great option, because what you mentioned not clear enough to implement
Where I can find this setting
It’s a hidden setting, you need to use the console, but you also need to configure the container, recommend you wait a few more weeks
Thank you, I appreciate your fantastic work
On my website (Arabic Forum), I conducted a test in Arabic by adding legislation in the first post (“topic”) and then asked questions using AI. However, the answers were inaccurate, and I believe this is because it is not Context Ragging.
Sorry but this is not how it works, you need to define a persona or tool and then add the upload there.
There has been some discussion around supporting “upload and ask” here: Upload and discuss pdfs in composer but it is not supported yet.
First of all, really thank you for your great work. I really like it.
After playing around with the settings and changing the AI Model to Gemini-Flash-2.0, it worked great for me. Here’s the situation I have:
We are an Auditors, Accountants, and Tax Consultants community, and we needed a tool to share related laws and trigger discussions about them. This discussion should be very useful for visitors, as we are professionals in our field. We are targeting the AI Model to check and analyze legislation and answer our questions. The great experiment led to the conclusion that we can really discuss the context added in the first post, and if the AI model is smart enough, it will answer our questions with very high-quality output.
Really thank you again and looking forward to the PDF support as it will make Discourse best forum Sofware
Latest image of discourse supports the advanced mode if anyone feels like testing
Does it have to be enabled via console? Don’t see any advanced mode options via the UI.
Furthermore, I am getting an error when trying to upload this pdf. It is 34 MB but I have my max attachment size set to 100 MB (in both admin settings and app.yml). What’s strange is that I have a compressed version which is 16 MB and it uploads just fine. But perhaps the larger PDF is simply too complex for now? There are lots of images, equations, etc.
Yes, you need to SiteSetting.ai_rag_images_enabled = true in the Rails console to enable it.
my guess here is that some nginx stuff needs to change in the container as well so it does not do the rejecting
Hi @sam
im currently having trouble to upload and indexing the pdfs by this error Job exception: undefined method `length’ for nil.
i was wondering if the error related to the settings we discussed above.
the interface will stuck on indexing 0% not move and
the exception details as below:
/var/www/discourse/plugins/discourse-ai/app/jobs/regular/digest_rag_upload.rb:81:in `chunk_document'
/var/www/discourse/plugins/discourse-ai/app/jobs/regular/digest_rag_upload.rb:40:in `block in execute'
activerecord-7.2.2.1/lib/active_record/connection_adapters/abstract/transaction.rb:616:in `block in within_new_transaction'
activesupport-7.2.2.1/lib/active_support/concurrency/null_lock.rb:9:in `synchronize'
activerecord-7.2.2.1/lib/active_record/connection_adapters/abstract/transaction.rb:613:in `within_new_transaction'
activerecord-7.2.2.1/lib/active_record/connection_adapters/abstract/database_statements.rb:361:in `transaction'
activerecord-7.2.2.1/lib/active_record/transactions.rb:234:in `block in transaction'
activerecord-7.2.2.1/lib/active_record/connection_adapters/abstract/connection_pool.rb:415:in `with_connection'
activerecord-7.2.2.1/lib/active_record/connection_handling.rb:296:in `with_connection'
activerecord-7.2.2.1/lib/active_record/transactions.rb:233:in `transaction'
/var/www/discourse/plugins/discourse-ai/app/jobs/regular/digest_rag_upload.rb:39:in `execute'
/var/www/discourse/app/jobs/base.rb:316:in `block (2 levels) in perform'
rails_multisite-6.1.0/lib/rails_multisite/connection_management/null_instance.rb:49:in `with_connection'
rails_multisite-6.1.0/lib/rails_multisite/connection_management.rb:21:in `with_connection'
/var/www/discourse/app/jobs/base.rb:303:in `block in perform'
/var/www/discourse/app/jobs/base.rb:299:in `each'
/var/www/discourse/app/jobs/base.rb:299:in `perform'
sidekiq-7.3.9/lib/sidekiq/processor.rb:220:in `execute_job'
sidekiq-7.3.9/lib/sidekiq/processor.rb:185:in `block (4 levels) in process'
sidekiq-7.3.9/lib/sidekiq/middleware/chain.rb:180:in `traverse'
sidekiq-7.3.9/lib/sidekiq/middleware/chain.rb:183:in `block in traverse'
/var/www/discourse/lib/sidekiq/pausable.rb:132:in `call'
sidekiq-7.3.9/lib/sidekiq/middleware/chain.rb:182:in `traverse'
sidekiq-7.3.9/lib/sidekiq/job/interrupt_handler.rb:9:in `call'
sidekiq-7.3.9/lib/sidekiq/metrics/tracking.rb:26:in `track'
sidekiq-7.3.9/lib/sidekiq/metrics/tracking.rb:134:in `call'
sidekiq-7.3.9/lib/sidekiq/middleware/chain.rb:173:in `invoke'
sidekiq-7.3.9/lib/sidekiq/processor.rb:184:in `block (3 levels) in process'
sidekiq-7.3.9/lib/sidekiq/processor.rb:145:in `block (6 levels) in dispatch'
sidekiq-7.3.9/lib/sidekiq/job_retry.rb:118:in `local'
sidekiq-7.3.9/lib/sidekiq/processor.rb:144:in `block (5 levels) in dispatch'
sidekiq-7.3.9/lib/sidekiq/config.rb:39:in `block in <class:Config>'
sidekiq-7.3.9/lib/sidekiq/processor.rb:139:in `block (4 levels) in dispatch'
sidekiq-7.3.9/lib/sidekiq/processor.rb:281:in `stats'
sidekiq-7.3.9/lib/sidekiq/processor.rb:134:in `block (3 levels) in dispatch'
sidekiq-7.3.9/lib/sidekiq/job_logger.rb:15:in `call'
sidekiq-7.3.9/lib/sidekiq/processor.rb:133:in `block (2 levels) in dispatch'
sidekiq-7.3.9/lib/sidekiq/job_retry.rb:85:in `global'
sidekiq-7.3.9/lib/sidekiq/processor.rb:132:in `block in dispatch'
sidekiq-7.3.9/lib/sidekiq/job_logger.rb:40:in `prepare'
sidekiq-7.3.9/lib/sidekiq/processor.rb:131:in `dispatch'
sidekiq-7.3.9/lib/sidekiq/processor.rb:183:in `block (2 levels) in process'
sidekiq-7.3.9/lib/sidekiq/processor.rb:182:in `handle_interrupt'
sidekiq-7.3.9/lib/sidekiq/processor.rb:182:in `block in process'
sidekiq-7.3.9/lib/sidekiq/processor.rb:181:in `handle_interrupt'
sidekiq-7.3.9/lib/sidekiq/processor.rb:181:in `process'
sidekiq-7.3.9/lib/sidekiq/processor.rb:86:in `process_one'
sidekiq-7.3.9/lib/sidekiq/processor.rb:76:in `run'
sidekiq-7.3.9/lib/sidekiq/component.rb:10:in `watchdog'
sidekiq-7.3.9/lib/sidekiq/component.rb:19:in `block in safe_thread'
thanks for this amazing update,
just have once concern here, 100mb limit for each Persona AI bot or for all Personas
I’m new to Discourse AI but an old hand on Discourses generally.
Really keen to try this out for a specific use case in demo form at this stage.
I’ve enabled the hidden site setting.
Nothing in SideKiq that I can see. How can I see if it is working at all?
I’m aware this is a pre release feature and not ready for prime time yet, however it would be great to be able to experience and try out.
Really keen for any hints, tips, screenshots, or recipes from people that are trying this out.
Ik krijg deze foutmelding wanneer ik de bot vraag om de inhoud van enkele PDF’s op mijn site samen te vatten. Ik heb de verbeterde verwerking niet ingeschakeld en gebruik GPT 4.1. Ideeën over wat ik verkeerd doe?
Sorry, het lijkt erop dat ons systeem een onverwacht probleem is tegengekomen bij het proberen te reageren.
Foutdetails
“error”: {
“message”: “Een assistentbericht met ‘tool_calls’ moet worden gevolgd door toolberichten die reageren op elke ‘tool_call_id’. De volgende tool_call_ids hadden geen antwoordberichten: call_nrDCba5mt83oavbXfPq2BtEV”,
“type”: “invalid_request_error”,
“param”: “messages.[2].role”,
“code”: null
May I inquire into the current status of PDF support? :face_with_peeking_eye:
When you configure upload sizes in app.yml it is site-wide, so it applies to each persona.
Are there any updates on this matter? I’m attaching a PDF when initiating a conversation with the AI, but it still doesn’t seem to recognize it. I am currently utilizing GPT. Should I perhaps consider employing a different model specifically designed for PDF processing?
