パフォーマンス最適化のヒント
こんにちは、
当社のサイトはかなり大規模です(PGベースは97GB)+ 256GBの画像を保存しています。
Digital Oceanサーバーで稼働しています — 6 vCPU / 16GB / 320GBディスク。
PGを最適化したり、何かを再構築して処理速度を向上させるためのヒント、トリック、スクリプトはありますか?
よろしくお願いします。
時々、最新のページが表示されるのに時間がかかります。
アクションの実行: latest
T+125.6 ms
Reader
7237.4 ms
app/models/topic_tracking_state.rb:301:in `report'
app/controllers/application_controller.rb:628:in `preload_current_user_data'
app/controllers/application_controller.rb:428:in `preload_json'
app/controllers/application_controller.rb:404:in `block in with_resolved_locale'
app/controllers/application_controller.rb:404:in `with_resolved_locale'
lib/middleware/omniauth_bypass_middleware.rb:71:in `call'
lib/middleware/anonymous_cache.rb:368:in `call'
config/initializers/100-quiet_logger.rb:23:in `call'
config/initializers/100-silence_logger.rb:31:in `call'
lib/middleware/enforce_hostname.rb:23:in `call'
lib/middleware/request_tracker.rb:202:in `call'
SELECT
           DISTINCT topics.id as topic_id,
           u.id as user_id,
           topics.created_at,
           topics.updated_at,
           topics.highest_staff_post_number AS highest_post_number,
           last_read_post_number,
           c.id as category_id,
           tu.notification_level,
           us.first_unread_at,
           GREATEST(
              CASE
              WHEN COALESCE(uo.new_topic_duration_minutes, 10080) = -1 THEN u.created_at
              WHEN COALESCE(uo.new_topic_duration_minutes, 10080) = -2 THEN COALESCE(
                u.previous_visit_at,u.created_at
              ELSE ('2022-05-11 22:22:20.701444'::timestamp - INTERVAL '1 MINUTE' * COALESCE(uo.new_topic_duration_minutes, 10080))
              END, u.created_at, '2022-05-03 03:50:38'
           ) AS treat_as_new_topic_start_date
FROM topics
JOIN users u on u.id = 1
JOIN user_stats AS us ON us.user_id = u.id
JOIN user_options AS uo ON uo.user_id = u.id
JOIN categories c ON c.id = topics.category_id
LEFT JOIN topic_users tu ON tu.topic_id = topics.id AND tu.user_id = u.id
LEFT JOIN dismissed_topic_users ON dismissed_topic_users.topic_id = topics.id AND dismissed_topic_users.user_id = 1
WHERE u.id = 1 AND
      topics.archetype <> 'private_message' AND
      ((1=0) OR ("topics"."deleted_at" IS NULL AND (topics.created_at >= (GREATEST(CASE
                  WHEN COALESCE(uo.new_topic_duration_minutes, 10080) = -2 THEN COALESCE(u.previous_visit_at,u.created_at)
                  ELSE ('2022-05-11 22:22:20.699581'::timestamp - INTERVAL '1 MINUTE' * COALESCE(uo.new_topic_duration_minutes, 10080))
               END, u.created_at, '2022-05-03 03:50:38'))) AND (tu.last_read_post_number IS NULL) AND (COALESCE(tu.notification_level, 2) >= 2) AND topics.created_at > '2022-05-03 03:50:38' AND dismissed_topic_users.id IS NULL)) AND
      topics.deleted_at IS NULL AND
      NOT (
        last_read_post_number IS NULL AND
          topics.category_id IN (SELECT "categories"."id" FROM "categories" LEFT JOIN categories categories2 ON categories2.id = categories.parent_category_id LEFT JOIN category_users ON category_users.category_id = categories.id AND category_users.user_id = 1 LEFT JOIN category_users category_users2 ON category_users2.category_id = categories2.id AND category_users2.user_id = 1 WHERE ((category_users.id IS NULL AND COALESCE(category_users2.notification_level, 1) = 0) OR COALESCE(category_users.notification_level, 1) = 0))
          AND tu.notification_level <= 1
UNION ALL
SELECT
           u.id as user_id,
           topics.created_at,
           topics.updated_at,
           us.first_unread_at,
           GREATEST(
              CASE
FROM topics
WHERE u.id = 1 AND
       topics.updated_at >= us.first_unread_at AND
      (("topics"."deleted_at" IS NULL AND (tu.last_read_post_number < topics.highest_staff_post_number) AND (COALESCE(tu.notification_level, 1) >= 2)) OR (1=0)) AND
      NOT (
 LIMIT 5000;
pg13への移行を推進した理由の1つは、pg13が提供する高速化です。そのため、PostgreSQL 13アップデートで説明されているようにインデックスを再構築することが最初に行うべきことです。
サーバーをより強力なホスティングにクリーンインストールとバックアップからの復元で移行しました。はい、今はずっと高速です!しかし、「いいね」機能にボトルネックがあります。いいねを作成するのに23秒かかります。
アクションの実行: create
T+229.3 ms
Reader
23169.7 ms
app/models/topic_user.rb:463:in `update_post_action_cache'
app/models/post_action.rb:232:in `update_counters'
lib/post_action_creator.rb:268:in `create_post_action'
lib/post_action_creator.rb:112:in `perform'
app/controllers/post_actions_controller.rb:22:in `create'
app/controllers/application_controller.rb:415:in `block in with_resolved_locale'
app/controllers/application_controller.rb:415:in `with_resolved_locale'
UPDATE topic_users tu
SET liked = x.state
FROM (
  SELECT CASE WHEN EXISTS (
    SELECT 1
    FROM post_actions pa
    JOIN posts p on p.id = pa.post_id
    JOIN topics t ON t.id = p.topic_id
    WHERE pa.deleted_at IS NULL AND
          p.deleted_at IS NULL AND
          t.deleted_at IS NULL AND
          pa.post_action_type_id = 2 AND
          tu2.topic_id = t.id AND
          tu2.user_id = pa.user_id
    LIMIT 1
  ) THEN true ELSE false END state, tu2.topic_id, tu2.user_id
  FROM topic_users tu2
  WHERE (tu2.user_id IN (1)) AND (tu2.topic_id IN (127680))
) x
WHERE x.topic_id = tu.topic_id AND x.user_id = tu.user_id AND x.state != tu.liked
DBの調整や再インデックスにもっと時間が必要ですか、それとも問題がありますか?
