Pinning Topics in Subcategories + Parent Category
Users are requesting a feature to pin topics in subcategories so they appear pinned in both the subcategory and parent category. markersocial suggests this would help ensure visibility for important resources, especially for users arriving via search engines. jomaxro asks for clarification on the use case. trudat explains their need to have guide topics in subcategories (like “Winter,” “Spring”) also appear pinned in the parent “Seasons” category, arguing this should be default behavior or at least an option. Tris20 adds that announcements in subcategories like “Announcements” should also be visible in the parent category (e.g., “Gitlab”) to ensure all users see critical updates like planned downtime, as the current workaround of pinning only in the parent causes confusion.
I think it would be very useful to have the option when pinning a subcategory topic to make it pinned for both the subcategory and parent category, instead of just the subcategory.
I see discussions of similar (but for not pinning subcategory topics in the parent category) here:
4 إعجابات
This is an interesting idea, I’m curious what your use-case is?
إعجاب واحد (1)
@jomaxro Thanks for your response. There is a list of highly relevant resources that I’d like to make pinned/available in both the subcategory and parent category. Visitors from Google may perhaps only go to the subcategory, or the parent category. If it isn’t available in both they may miss it.
إعجاب واحد (1)
I would also like to have pinned topics in a subcategory appear as pinned in the parent category.
My use case is this:
  • I am using a category tree to organize a large amount of content; essentially reference documents that are open for comment. Let’s call the parent category Seasons, with four subcategories Winter, Spring, Summer, Fall, and each subcategory has 20 topics.
  • One topic in each subcategory acts as a guide, including links to some of the topics within that subcategory. That guide topic is pinned.
  • If the user accesses the parent category Seasons they should see at the top the four guide topics, one for each of the subcategories. And within the subcategory, it should also be pinned.
This seems to me like it should be the default behavior. But at the very least it should be an option in the pinning dialogue.
3 إعجابات
وأود أيضًا رؤية هذا. من الناحية المثالية مع خيار لتثبيته في كل من الأصل والفرع.
حالة الاستخدام:
الفئة = Gitlab
الفئة الفرعية = الإعلانات
الموضوع = وقت التوقف المخطط له
وقت التوقف المخطط له هو إعلان. ومع ذلك، فإن الإعلانات اختيارية، مما يعني أن جميع المستخدمين لن يرونها. وبالتالي، نريد أيضًا تثبيتها في الفئة الأصلية.
الحل البديل الحالي هو تثبيتها في الأصل لزيادة الرؤية، ولكن هذا مربك للمستخدمين الذين يبحثون عن مثل هذه المعلومات (بشكل صحيح) في الإعلانات.
إعجاب واحد (1)
