I declared a myplugin_enabled site setting in config/settings.yml, config/locales/server.en.yml and plugin.rb (as described here),.
However, I’ve recently discovered that unchecking the box doesn’t disable my plugin. The plugin is loaded - and works correctly, including accessing other site settings - whatever the checkbox state.
Any hint?
That isn’t how that setting is meant to work. It is meant for you to disable your plugins behavior (in code) . Your plugin still gets loaded.
Thanks @cpradio, that helps a lot.
Maybe this could be clarified in the @eviltrout’s page I mentioned earlier.
I guess the enabled_site_setting :myplugin_enabled line relates to “multisite setup”, as stated here, but at this stage I have no idea what it is
I face similar issue.
after_initialize do
::Topic.class_eval do
after_commit do
#myplugin code
No matter if myplugin_enabled is true/false, myplugin code is executed. I don’t see any use for enabled_site_setting either. Can anyone explain what exactly it is? How can I enable/disable myplugin code based on myplugin_enabled value?
Use if SiteSetting.myplugin_enabled to check for that.
Yeah, that is how I’m currently doing it. But I don’t see any use for enabled_site_setting: myplugin_enabled. It doesn’t make any difference if I keep/remove it. I’m trying to understand it. As explained here, it turns our features on and off
It’s an on/off switch with the special property that it shows up on the Admin / Plugins screen.
Discourse doesn’t actually have a clean way to undo the effects of a loaded plugin, so it trusts the plugin code to be checking that setting instead.
