Must be Ember.ContainerView.extend({tagName: ''}) instead of Ember.ContainerView.
The current wrong code breaks HTML markup in cases where HTML syntax does not allow wrapper DIV tag.
An example is admin-menu plugin outlet:
If there are multiple admin-menu connectors then Discourse wrongly renders them as:
<ul>
<!-- standard menu items: -->
<li></li>
<li></li>
<!-- admin-menu connectors: -->
<div>
<li></li>
<li></li>
</div>
</ul>
Oops I see what you mean Sam. If I apply the tagname to the ContainerView it’s not what you want, because then you are expecting the children to have li too.
I’m gonna ask people about this. Maybe I can append to the Morph.
Replacing Ember.ContainerView to Ember.ContainerView.extend({tagName: ''}) as I described in the first message definitely works, I have tested it for my multiple plugins at admin-menu outlet.
It didn’t work when I tried it. If you pass the tagName to the ContainerView the container gets the li tag, but then the children get div tags. So adding two <li> doesn’t work.
Except, I think that is valid HTML now (as of HTML 5). I think li can contain block elements (such as div), so that is less of a problem than the li being wrapped in a div.
Sure a widget could be mounted with a metamorph or something similar - the problem is you always need a {{mount-widget}} to start hosting them and that needs a tag.
