주제 진입 시 플러그인에서 예외 발생
포럼의 특정 주제를 입력할 때 로그에 다음과 같은 예외 메시지가 표시됩니다.
/var/www/discourse/plugins/discourse-translator/services/discourse_translator/microsoft.rb:69:in `access_token'
/var/www/discourse/plugins/discourse-translator/services/discourse_translator/microsoft.rb:151:in `default_headers'
/var/www/discourse/plugins/discourse-translator/services/discourse_translator/microsoft.rb:89:in `detect'
/var/www/discourse/plugins/discourse-translator/plugin.rb:108:in `block in execute'
/var/www/discourse/lib/distributed_mutex.rb:33:in `block in synchronize'
/var/www/discourse/lib/distributed_mutex.rb:29:in `synchronize'
/var/www/discourse/lib/distributed_mutex.rb:14:in `synchronize'
/var/www/discourse/plugins/discourse-translator/plugin.rb:107:in `execute'
/var/www/discourse/app/jobs/base.rb:232:in `block (2 levels) in perform'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rails_multisite-2.0.7/lib/rails_multisite/connection_management.rb:63:in `with_connection'
/var/www/discourse/app/jobs/base.rb:221:in `block in perform'
/var/www/discourse/app/jobs/base.rb:217:in `each'
/var/www/discourse/app/jobs/base.rb:217:in `perform'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sidekiq-5.2.7/lib/sidekiq/processor.rb:192:in `execute_job'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sidekiq-5.2.7/lib/sidekiq/processor.rb:165:in `block (2 levels) in process'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sidekiq-5.2.7/lib/sidekiq/middleware/chain.rb:128:in `block in invoke'
/var/www/discourse/lib/sidekiq/pausable.rb:138:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sidekiq-5.2.7/lib/sidekiq/middleware/chain.rb:130:in `block in invoke'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sidekiq-5.2.7/lib/sidekiq/middleware/chain.rb:133:in `invoke'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sidekiq-5.2.7/lib/sidekiq/processor.rb:164:in `block in process'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sidekiq-5.2.7/lib/sidekiq/processor.rb:137:in `block (6 levels) in dispatch'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sidekiq-5.2.7/lib/sidekiq/job_retry.rb:109:in `local'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sidekiq-5.2.7/lib/sidekiq/processor.rb:136:in `block (5 levels) in dispatch'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sidekiq-5.2.7/lib/sidekiq.rb:37:in `block in <module:Sidekiq>'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sidekiq-5.2.7/lib/sidekiq/processor.rb:132:in `block (4 levels) in dispatch'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sidekiq-5.2.7/lib/sidekiq/processor.rb:250:in `stats'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sidekiq-5.2.7/lib/sidekiq/processor.rb:127:in `block (3 levels) in dispatch'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sidekiq-5.2.7/lib/sidekiq/job_logger.rb:8:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sidekiq-5.2.7/lib/sidekiq/processor.rb:126:in `block (2 levels) in dispatch'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sidekiq-5.2.7/lib/sidekiq/job_retry.rb:74:in `global'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sidekiq-5.2.7/lib/sidekiq/processor.rb:125:in `block in dispatch'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sidekiq-5.2.7/lib/sidekiq/logging.rb:48:in `with_context'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sidekiq-5.2.7/lib/sidekiq/logging.rb:42:in `with_job_hash_context'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sidekiq-5.2.7/lib/sidekiq/processor.rb:124:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sidekiq-5.2.7/lib/sidekiq/processor.rb:163:in `process'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sidekiq-5.2.7/lib/sidekiq/processor.rb:83:in `process_one'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sidekiq-5.2.7/lib/sidekiq/processor.rb:71:in `run'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sidekiq-5.2.7/lib/sidekiq/util.rb:16:in `watchdog'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sidekiq-5.2.7/lib/sidekiq/util.rb:25:in `block in safe_thread'
액세스 토큰이 제대로 설정되지 않은 것 같네요?
그거 재밌었어요. 마이크로소프트가 제 계정을 잠갔고 번역 토큰도 작동하지 않게 됐는데, 어떤 종류의 임시 토큰이 여전히 작동하는 것 같아서 플러그인 설정에서 같은 토큰을 삭제하고 다시 붙여넣기할 때까지는 번역이 정상적으로 작동했어요. 그 이후로는 번역이 완전히 멈췄죠.
해결했습니다. 플러그인 문제는 아니에요.
