Png favicon not appearing in Chrome (Mixed content error)
Hi,
The 32x32 favicon that I uploaded into a https locally hosted discourse is going into the HTML with
<link rel="icon" type="image/png" href="http://discourse.jalview.org/uploads/default/optimized/1X/c29815ed01e3ce7d1cc583ccc9feaada4bae5d4b_2_32x32.png">
and you can see the problem in Chrome:
and
Is there a way to force this to be an https URL?
Thank you!
Ben
Yes, and it is enabled by default when you setup a new Discourse install using a proper domain. If it failed, or this an old install you can ssh and:
cd /var/discourse
./launcher enter app
rails c
SiteSetting.force_https = true
@Falco Thanks that has fixed it.
The local discourse is behind a reverse proxy and so the actual install probably wan’t running as https when first installed.
