Erro no PostgreSQL ao reconstruir
Olá,
Quando recrio meu Discourse hoje via ./launcher rebuild app, recebo os seguintes erros:
root@discourse:/opt# cd /var/discourse_docker/
root@discourse:/var/discourse_docker# ./launcher rebuild app
Garantindo que o launcher está atualizado
Buscando origin
Launcher está atualizado
cd /pups && git pull && /pups/bin/pups --stdin
Já está atualizado.
I, [2020-07-15T16:31:19.389969 #1]  INFO -- : Carregando --stdin
I, [2020-07-15T16:31:19.397738 #1]  INFO -- : > locale-gen $LANG && update-locale
I, [2020-07-15T16:31:19.442371 #1]  INFO -- : Gerando locais (isso pode levar algum tempo)...
Geração concluída.
I, [2020-07-15T16:31:19.442561 #1]  INFO -- : > mkdir -p /shared/postgres_run
I, [2020-07-15T16:31:19.445577 #1]  INFO -- :
I, [2020-07-15T16:31:19.445781 #1]  INFO -- : > chown postgres:postgres /shared/postgres_run
I, [2020-07-15T16:31:19.449166 #1]  INFO -- :
I, [2020-07-15T16:31:19.449376 #1]  INFO -- : > chmod 775 /shared/postgres_run
I, [2020-07-15T16:31:19.452432 #1]  INFO -- :
I, [2020-07-15T16:31:19.452626 #1]  INFO -- : > rm -fr /var/run/postgresql
I, [2020-07-15T16:31:19.456077 #1]  INFO -- :
I, [2020-07-15T16:31:19.456274 #1]  INFO -- : > ln -s /shared/postgres_run /var/run/postgresql
I, [2020-07-15T16:31:19.459496 #1]  INFO -- :
I, [2020-07-15T16:31:19.459722 #1]  INFO -- : > socat /dev/null UNIX-CONNECT:/shared/postgres_run/.s.PGSQL.5432 || exit 0 && echo postgres já está rodando, pare o container ; exit 1
2020/07/15 16:31:19 socat[26] E connect(6, AF=1 "/shared/postgres_run/.s.PGSQL.5432", 36): Arquivo ou diretório não encontrado
I, [2020-07-15T16:31:19.466033 #1]  INFO -- :
I, [2020-07-15T16:31:19.466190 #1]  INFO -- : > rm -fr /shared/postgres_run/.s*
I, [2020-07-15T16:31:19.470412 #1]  INFO -- :
I, [2020-07-15T16:31:19.470594 #1]  INFO -- : > rm -fr /shared/postgres_run/*.pid
I, [2020-07-15T16:31:19.474721 #1]  INFO -- :
I, [2020-07-15T16:31:19.474886 #1]  INFO -- : > mkdir -p /shared/postgres_run/12-main.pg_stat_tmp
I, [2020-07-15T16:31:19.477948 #1]  INFO -- :
I, [2020-07-15T16:31:19.478165 #1]  INFO -- : > chown postgres:postgres /shared/postgres_run/12-main.pg_stat_tmp
I, [2020-07-15T16:31:19.481360 #1]  INFO -- :
I, [2020-07-15T16:31:19.488377 #1]  INFO -- : Arquivo > /etc/service/postgres/run  chmod: +x  chown:
I, [2020-07-15T16:31:19.494864 #1]  INFO -- : Arquivo > /etc/service/postgres/log/run  chmod: +x  chown:
I, [2020-07-15T16:31:19.501433 #1]  INFO -- : Arquivo > /etc/runit/3.d/99-postgres  chmod: +x  chown:
I, [2020-07-15T16:31:19.508030 #1]  INFO -- : Arquivo > /root/upgrade_postgres  chmod: +x  chown:
I, [2020-07-15T16:31:19.508311 #1]  INFO -- : > chown -R root /var/lib/postgresql/12/main
I, [2020-07-15T16:31:22.627505 #1]  INFO -- :
I, [2020-07-15T16:31:22.627827 #1]  INFO -- : > [ ! -e /shared/postgres_data ] && install -d -m 0755 -o postgres -g postgres /shared/postgres_data && sudo -E -u postgres /usr/lib/postgresql/12/bin/initdb -D /shared/postgres_data || exit 0
I, [2020-07-15T16:31:22.631480 #1]  INFO -- :
I, [2020-07-15T16:31:22.631656 #1]  INFO -- : > chown -R postgres:postgres /shared/postgres_data
I, [2020-07-15T16:31:22.649989 #1]  INFO -- :
I, [2020-07-15T16:31:22.650148 #1]  INFO -- : > chown -R postgres:postgres /var/run/postgresql
I, [2020-07-15T16:31:22.653807 #1]  INFO -- :
I, [2020-07-15T16:31:22.654052 #1]  INFO -- : > /root/upgrade_postgres
I, [2020-07-15T16:31:22.660478 #1]  INFO -- :
I, [2020-07-15T16:31:22.660651 #1]  INFO -- : > rm /root/upgrade_postgres
I, [2020-07-15T16:31:22.663338 #1]  INFO -- :
I, [2020-07-15T16:31:22.663767 #1]  INFO -- : Substituindo data_directory = '/var/lib/postgresql/12/main' por data_directory = '/shared/postgres_data' em /etc/postgresql/12/main/postgresql.conf
I, [2020-07-15T16:31:22.664582 #1]  INFO -- : Substituindo (?-mix:#?listen_addresses *=.*) por listen_addresses = '*' em /etc/postgresql/12/main/postgresql.conf
I, [2020-07-15T16:31:22.666768 #1]  INFO -- : Substituindo (?-mix:#?synchronous_commit *=.*) por synchronous_commit = $db_synchronous_commit em /etc/postgresql/12/main/postgresql.conf
I, [2020-07-15T16:31:22.668210 #1]  INFO -- : Substituindo (?-mix:#?shared_buffers *=.*) por shared_buffers = $db_shared_buffers em /etc/postgresql/12/main/postgresql.conf
I, [2020-07-15T16:31:22.669770 #1]  INFO -- : Substituindo (?-mix:#?work_mem *=.*) por work_mem = $db_work_mem em /etc/postgresql/12/main/postgresql.conf
I, [2020-07-15T16:31:22.671341 #1]  INFO -- : Substituindo (?-mix:#?default_text_search_config *=.*) por default_text_search_config = '$db_default_text_search_config' em /etc/postgresql/12/main/postgresql.conf
I, [2020-07-15T16:31:22.673141 #1]  INFO -- : > install -d -m 0755 -o postgres -g postgres /shared/postgres_backup
I, [2020-07-15T16:31:22.676724 #1]  INFO -- :
I, [2020-07-15T16:31:22.677097 #1]  INFO -- : Substituindo (?-mix:#?max_wal_senders *=.*) por max_wal_senders = $db_max_wal_senders em /etc/postgresql/12/main/postgresql.conf
I, [2020-07-15T16:31:22.677542 #1]  INFO -- : Substituindo (?-mix:#?wal_level *=.*) por wal_level = $db_wal_level em /etc/postgresql/12/main/postgresql.conf
I, [2020-07-15T16:31:22.679169 #1]  INFO -- : Substituindo (?-mix:#?checkpoint_segments *=.*) por checkpoint_segments = $db_checkpoint_segments em /etc/postgresql/12/main/postgresql.conf
I, [2020-07-15T16:31:22.680967 #1]  INFO -- : Substituindo (?-mix:#?logging_collector *=.*) por logging_collector = $db_logging_collector em /etc/postgresql/12/main/postgresql.conf
I, [2020-07-15T16:31:22.682498 #1]  INFO -- : Substituindo (?-mix:#?log_min_duration_statement *=.*) por log_min_duration_statement = $db_log_min_duration_statement em /etc/postgresql/12/main/postgresql.conf
I, [2020-07-15T16:31:22.684043 #1]  INFO -- : Substituindo (?-mix:^#local +replication +postgres +peer$) por local replication postgres  peer em /etc/postgresql/12/main/pg_hba.conf
I, [2020-07-15T16:31:22.684445 #1]  INFO -- : Substituindo (?-mix:^host.*all.*all.*127.*$) por host all all 0.0.0.0/0 md5 em /etc/postgresql/12/main/pg_hba.conf
I, [2020-07-15T16:31:22.685537 #1]  INFO -- : > HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/12/bin/postmaster -D /etc/postgresql/12/main
I, [2020-07-15T16:31:22.687451 #1]  INFO -- : > sleep 5
2020-07-15 16:31:22.703 GMT [49] LOG:  erro de sintaxe no arquivo "/etc/postgresql/12/main/postgresql.conf" linha 193, próximo ao token "$"
2020-07-15 16:31:22.703 GMT [49] LOG:  erro de sintaxe no arquivo "/etc/postgresql/12/main/postgresql.conf" linha 286, próximo ao token "$"
2020-07-15 16:31:22.703 GMT [49] FATAL:  arquivo de configuração "/etc/postgresql/12/main/postgresql.conf" contém erros
I, [2020-07-15T16:31:27.690822 #1]  INFO -- :
I, [2020-07-15T16:31:27.691358 #1]  INFO -- : > su postgres -c 'createdb discourse' || true
Erro: linha 193 inválida em /etc/postgresql/12/main/postgresql.conf: wal_level = $db_wal_level
I, [2020-07-15T16:31:27.755611 #1]  INFO -- :
I, [2020-07-15T16:31:27.755836 #1]  INFO -- : > su postgres -c 'psql discourse -c "create user discourse;"' || true
I, [2020-07-15T16:31:27.811853 #1]  INFO -- :
I, [2020-07-15T16:31:27.812171 #1]  INFO -- : > su postgres -c 'psql discourse -c "grant all privileges on database discourse to discourse;"' || true
I, [2020-07-15T16:31:27.865404 #1]  INFO -- :
I, [2020-07-15T16:31:27.865605 #1]  INFO -- : > su postgres -c 'psql discourse -c "alter schema public owner to discourse;"'
I, [2020-07-15T16:31:27.917261 #1]  INFO -- :
I, [2020-07-15T16:31:27.917634 #1]  INFO -- : Encerrando processos assíncronos
FALHA
Pups::ExecError: su postgres -c 'psql discourse -c "alter schema public owner to discourse;"' falhou com retorno #<Process::Status: pid 61 exit 1>
Local da falha: /pups/lib/pups/exec_command.rb:112:in `spawn'
exec falhou com os parâmetros "su postgres -c 'psql $db_name -c \"alter schema public owner to $db_user;\"'"
7670f9fb0161c9f213e14e09345518109b1ec04131d0428375f112ffccb98337
** FALHA NO BOOTSTRAP ** por favor, role para cima e procure mensagens de erro anteriores, pode haver mais de uma.
./discourse-doctor pode ajudar a diagnosticar o problema.
Também tentei apenas clonar novamente o repositório via git em GitHub - discourse/discourse_docker: A Docker image for Discourse · GitHub, mas o erro persiste. Alguma ajuda? O discourse_doctor não ajudou.
Tentei uma instalação limpa do Discourse e o erro ainda persiste.
Is this a PostgreSQL 12 upgrade error @Falco?
Mesmo problema em uma instalação nova no EC2 (Ubuntu 18.04.4 LTS) seguindo agora as instruções de instalação na nuvem:
    I, [2020-07-15T16:37:49.240541 #1]  INFO -- : > mkdir -p /shared/postgres_run
    I, [2020-07-15T16:37:49.242993 #1]  INFO -- :
    I, [2020-07-15T16:37:49.243332 #1]  INFO -- : > chown postgres:postgres /shared/postgres_run
    I, [2020-07-15T16:37:49.245340 #1]  INFO -- :
    I, [2020-07-15T16:37:49.245758 #1]  INFO -- : > chmod 775 /shared/postgres_run
    I, [2020-07-15T16:37:49.247483 #1]  INFO -- :
    I, [2020-07-15T16:37:49.247744 #1]  INFO -- : > rm -fr /var/run/postgresql
    I, [2020-07-15T16:37:49.249718 #1]  INFO -- :
    I, [2020-07-15T16:37:49.250109 #1]  INFO -- : > ln -s /shared/postgres_run /var/run/postgresql
    I, [2020-07-15T16:37:49.251780 #1]  INFO -- :
    I, [2020-07-15T16:37:49.252044 #1]  INFO -- : > socat /dev/null UNIX-CONNECT:/shared/postgres_run/.s.PGSQL.5432 || exit 0 && echo postgres já está em execução, pare o container ; exit 1
    2020/07/15 16:37:49 socat[26] E connect(6, AF=1 "/shared/postgres_run/.s.PGSQL.5432", 36): Arquivo ou diretório não encontrado
    I, [2020-07-15T16:37:49.255669 #1]  INFO -- :
    I, [2020-07-15T16:37:49.255932 #1]  INFO -- : > rm -fr /shared/postgres_run/.s*
    I, [2020-07-15T16:37:49.258317 #1]  INFO -- :
    I, [2020-07-15T16:37:49.258498 #1]  INFO -- : > rm -fr /shared/postgres_run/*.pid
    I, [2020-07-15T16:37:49.260852 #1]  INFO -- :
    I, [2020-07-15T16:37:49.261155 #1]  INFO -- : > mkdir -p /shared/postgres_run/12-main.pg_stat_tmp
    I, [2020-07-15T16:37:49.263194 #1]  INFO -- :
    I, [2020-07-15T16:37:49.263496 #1]  INFO -- : > chown postgres:postgres /shared/postgres_run/12-main.pg_stat_tmp
    I, [2020-07-15T16:37:49.265228 #1]  INFO -- :
    I, [2020-07-15T16:37:49.269169 #1]  INFO -- : Arquivo > /etc/service/postgres/run  chmod: +x  chown:
    I, [2020-07-15T16:37:49.272879 #1]  INFO -- : Arquivo > /etc/service/postgres/log/run  chmod: +x  chown:
    I, [2020-07-15T16:37:49.276415 #1]  INFO -- : Arquivo > /etc/runit/3.d/99-postgres  chmod: +x  chown:
    I, [2020-07-15T16:37:49.280134 #1]  INFO -- : Arquivo > /root/upgrade_postgres  chmod: +x  chown:
    I, [2020-07-15T16:37:49.280510 #1]  INFO -- : > chown -R root /var/lib/postgresql/12/main
    I, [2020-07-15T16:37:51.389258 #1]  INFO -- :
    I, [2020-07-15T16:37:51.389481 #1]  INFO -- : > [ ! -e /shared/postgres_data ] && install -d -m 0755 -o postgres -g postgres /shared/postgres_data && sudo -E -u postgres /usr/lib/postgresql/12/bin/initdb -D /shared/postgres_data || exit 0
    I, [2020-07-15T16:37:51.393651 #1]  INFO -- :
    I, [2020-07-15T16:37:51.393783 #1]  INFO -- : > chown -R postgres:postgres /shared/postgres_data
    I, [2020-07-15T16:37:51.401336 #1]  INFO -- :
    I, [2020-07-15T16:37:51.405711 #1]  INFO -- : > chown -R postgres:postgres /var/run/postgresql
    I, [2020-07-15T16:37:51.409068 #1]  INFO -- :
    I, [2020-07-15T16:37:51.409759 #1]  INFO -- : > /root/upgrade_postgres
    I, [2020-07-15T16:37:51.417131 #1]  INFO -- :
    I, [2020-07-15T16:37:51.417936 #1]  INFO -- : > rm /root/upgrade_postgres
    I, [2020-07-15T16:37:51.420632 #1]  INFO -- :
    I, [2020-07-15T16:37:51.421270 #1]  INFO -- : Substituindo data_directory = '/var/lib/postgresql/12/main' por data_directory = '/shared/postgres_data' em /etc/postgresql/12/main/postgresql.conf
    I, [2020-07-15T16:37:51.421970 #1]  INFO -- : Substituindo (?-mix:#?listen_addresses *=.*) por listen_addresses = '*' em /etc/postgresql/12/main/postgresql.conf
    I, [2020-07-15T16:37:51.423148 #1]  INFO -- : Substituindo (?-mix:#?synchronous_commit *=.*) por synchronous_commit = $db_synchronous_commit em /etc/postgresql/12/main/postgresql.conf
    I, [2020-07-15T16:37:51.424102 #1]  INFO -- : Substituindo (?-mix:#?shared_buffers *=.*) por shared_buffers = $db_shared_buffers em /etc/postgresql/12/main/postgresql.conf
    I, [2020-07-15T16:37:51.425086 #1]  INFO -- : Substituindo (?-mix:#?work_mem *=.*) por work_mem = $db_work_mem em /etc/postgresql/12/main/postgresql.conf
    I, [2020-07-15T16:37:51.426032 #1]  INFO -- : Substituindo (?-mix:#?default_text_search_config *=.*) por default_text_search_config = '$db_default_text_search_config' em /etc/postgresql/12/main/postgresql.conf
    I, [2020-07-15T16:37:51.426983 #1]  INFO -- : > install -d -m 0755 -o postgres -g postgres /shared/postgres_backup
    I, [2020-07-15T16:37:51.430084 #1]  INFO -- :
    I, [2020-07-15T16:37:51.430573 #1]  INFO -- : Substituindo (?-mix:#?max_wal_senders *=.*) por max_wal_senders = $db_max_wal_senders em /etc/postgresql/12/main/postgresql.conf
    I, [2020-07-15T16:37:51.431292 #1]  INFO -- : Substituindo (?-mix:#?wal_level *=.*) por wal_level = $db_wal_level em /etc/postgresql/12/main/postgresql.conf
    I, [2020-07-15T16:37:51.433312 #1]  INFO -- : Substituindo (?-mix:#?checkpoint_segments *=.*) por checkpoint_segments = $db_checkpoint_segments em /etc/postgresql/12/main/postgresql.conf
    I, [2020-07-15T16:37:51.434127 #1]  INFO -- : Substituindo (?-mix:#?logging_collector *=.*) por logging_collector = $db_logging_collector em /etc/postgresql/12/main/postgresql.conf
    I, [2020-07-15T16:37:51.435128 #1]  INFO -- : Substituindo (?-mix:#?log_min_duration_statement *=.*) por log_min_duration_statement = $db_log_min_duration_statement em /etc/postgresql/12/main/postgresql.conf
    I, [2020-07-15T16:37:51.436084 #1]  INFO -- : Substituindo (?-mix:^#local +replication +postgres +peer$) por local replication postgres  peer em /etc/postgresql/12/main/pg_hba.conf
    I, [2020-07-15T16:37:51.436566 #1]  INFO -- : Substituindo (?-mix:^host.*all.*all.*127.*$) por host all all 0.0.0.0/0 md5 em /etc/postgresql/12/main/pg_hba.conf
    I, [2020-07-15T16:37:51.437521 #1]  INFO -- : > HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/12/bin/postmaster -D /etc/postgresql/12/main
    I, [2020-07-15T16:37:51.440165 #1]  INFO -- : > sleep 5
    2020-07-15 16:37:51.457 GMT [49] LOG:  erro de sintaxe no arquivo "/etc/postgresql/12/main/postgresql.conf" linha 193, próximo ao token "$"
    2020-07-15 16:37:51.457 GMT [49] LOG:  erro de sintaxe no arquivo "/etc/postgresql/12/main/postgresql.conf" linha 286, próximo ao token "$"
    2020-07-15 16:37:51.457 GMT [49] FATAL:  arquivo de configuração "/etc/postgresql/12/main/postgresql.conf" contém erros
    I, [2020-07-15T16:37:56.451144 #1]  INFO -- :
    I, [2020-07-15T16:37:56.451405 #1]  INFO -- : > su postgres -c 'createdb discourse' || true
    I, [2020-07-15T16:37:56.503071 #1]  INFO -- :
    I, [2020-07-15T16:37:56.503968 #1]  INFO -- : > su postgres -c 'psql discourse -c "create user discourse;"' || true
    I, [2020-07-15T16:37:56.550717 #1]  INFO -- :
    I, [2020-07-15T16:37:56.550930 #1]  INFO -- : > su postgres -c 'psql discourse -c "grant all privileges on database discourse to discourse;"' || true
    I, [2020-07-15T16:37:56.612944 #1]  INFO -- :
    I, [2020-07-15T16:37:56.613161 #1]  INFO -- : > su postgres -c 'psql discourse -c "alter schema public owner to discourse;"'
    I, [2020-07-15T16:37:56.665397 #1]  INFO -- :
    I, [2020-07-15T16:37:56.665800 #1]  INFO -- : Encerrando processos assíncronos
    FALHA
    Localização da falha: /pups/lib/pups/exec_command.rb:112:in `spawn'
Exatamente o mesmo problema em um servidor DO novo
Estou recebendo isso ao reconstruir.
Consegui reconstruir adicionando os seguintes parâmetros ao templates/postgres.template.yml:
db_wal_level: minimal
db_max_wal_senders: 0
Sim. O novo commit na master removeu essa linha em todos os PostgreSQL.
Um teste de fumaça será suficiente para verificar se esse PR quebrou a branch master.
Correção confirmada para instalação nova. Obrigado!
params:
  db_synchronous_commit: "off"
  db_shared_buffers: "256MB"
  db_work_mem: "10MB"
  db_name: discourse
  db_user: discourse
  db_checkpoint_segments: 6
  db_logging_collector: off
  db_log_min_duration_statement: 100
Parece que isso não funcionou. Tenho aquele commit e ainda recebo:
Ah. Talvez eu esteja confuso.
I, [2020-07-15T17:11:53.608333 #1]  INFO -- : > HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/12/bin/postmaster -D /etc/postgresql/12/main
I, [2020-07-15T17:11:53.610211 #1]  INFO -- : > sleep 5
2020-07-15 17:11:53.641 GMT [49] LOG:  erro de sintaxe no arquivo "/etc/postgresql/12/main/postgresql.conf" na linha 193, próximo ao token "$"
2020-07-15 17:11:53.642 GMT [49] LOG:  erro de sintaxe no arquivo "/etc/postgresql/12/main/postgresql.conf" na linha 286, próximo ao token "$"
2020-07-15 17:11:53.643 GMT [49] FATAL:  arquivo de configuração "/etc/postgresql/12/main/postgresql.conf" contém erros
I, [2020-07-15T17:11:58.619578 #1]  INFO -- :
I, [2020-07-15T17:11:58.619911 #1]  INFO -- : > su postgres -c 'createdb discourse' || true
Erro: linha inválida 193 em /etc/postgresql/12/main/postgresql.conf: wal_level = $db_wal_level
I, [2020-07-15T17:11:58.700776 #1]  INFO -- :
I, [2020-07-15T17:11:58.701730 #1]  INFO -- : > su postgres -c 'psql discourse -c "create user discourse;"' || true
I, [2020-07-15T17:11:58.775094 #1]  INFO -- :
I, [2020-07-15T17:11:58.776049 #1]  INFO -- : > su postgres -c 'psql discourse -c "grant all privileges on database discourse to discourse;"' || true
I, [2020-07-15T17:11:58.847143 #1]  INFO -- :
I, [2020-07-15T17:11:58.848265 #1]  INFO -- : > su postgres -c 'psql discourse -c "alter schema public owner to discourse;"'
I, [2020-07-15T17:11:58.918991 #1]  INFO -- :
I, [2020-07-15T17:11:58.920088 #1]  INFO -- : Encerrando processos assíncronos
Mas parece que isso foi mesclado e
precisa ter $db_wal_level definido.
Desculpe por isso! Isso deveria ter sido removido completamente. Corrigido.
O novo commit corrigiu. Valeu, parceiro. Também testa sua coisa antes de mesclar na branch master :+1:
