Posts structured data: authors url is blocked by "noindex"
Structured Data Issue with Author URLs
rrit highlights a problem with the structured data in Discourse posts. The author’s URL is included in the schema, but it is blocked by the noindex HTTP header. According to Google’s guidelines, structured data pages should not be blocked to Googlebot.
Google recommends including the author’s URL in the schema to uniquely identify the author. However, Discourse’s current implementation uses a URL that is blocked by noindex.
A proposed solution is to remove the url property and use the itemid property instead, linking to the same author object without setting a URL. This would involve changing the code from:
<span class="creator" itemprop="author" itemscope="" itemtype="http://schema.org/Person">
  <a itemprop="url" href="https://meta.discourse.org/u/codinghorror">
    <span itemprop="name">codinghorror</span>
  </a>
  (Jeff Atwood)
</span>
to:
      itemid="https://meta.discourse.org/u/codinghorror"
  <a rel="nofollow" href="https://meta.discourse.org/u/codinghorror">
  </a>
  (Jeff Atwood)
</span>
This change would allow Discourse to comply with Google’s guidelines while maintaining the author’s URL in the schema.
In the strucured data of each Post there is an url to the authors page:
<div id="post_123" itemscope="" itemtype="http://schema.org/DiscussionForumPosting" class="topic-body crawler-post">
  <div class="crawler-post-meta">
      </a>
      (Jeff Atwood)
    </span>
These author pages are blocked by http-header noindex. Google wants all structured data to be accessible - see General Structured Data Guidelines | Google Search Central  |  Documentation  |  Google for Developers
The authors url is recommended by Google – see Learn About Article Schema Markup | Google Search Central  |  Documentation  |  Google for Developers
Should Discourse hide the authors url?
Hiding the url might be done by using the property itemid to link all posts from the same author to the same author object without setting any url.
Current state:
  </a>
  (Jeff Atwood)
</span>
Remove property url and add identifier via property itemid - additionally set rel="nofollow":
  </a>
  (Jeff Atwood)
</span>
