Prevent email addresses from being counted as mentions
Hi there,
Is there any built-in way to prevent this behaviour or is a plugin ?
Thanks!
Not sure I understand what you mean since emails aren’t counted as mention (test: foo@damien.bar).
I think he means that email addresses are counted against the max_mentions_per_post.
I can’t test it right now, but I think I noticed this too some time ago. Not sure if it still happens…
Aha if we can repro that we should fix @techapj.
Seems to be fixed… I could do that as a new user on try … http://try.discourse.org/t/this-is-alot-of-emails/356
Yeah this is bust … tagging as a bug
1@test.com 1@best.com @best @not
Post.find(162234).raw_mentions
=> ["test", "best", "not"]
There should be 0 raw mentions on my post here cause nobody was mentioned.
Exactly, sorry I could not provide more input.
I could not see any post or issue related to this problem, and I thought that may be related to some misusage of the application in some way eheh
Thanks for the quick answer!
This is now fixed :pizza:
Thanks @damien for reporting that issue :slightly_smiling:
