Problem-Setup auf AWS: EC2, RDS, ElastiCache
Hi,
I have been following this guide to install Discourse on whole AWS services.
EC2 for Instance, RDS for Database, ElastiCache for Redis, Cloudfront for CDN and finally SES for Emails.
No problem for Cloudfront and SES.
However, I am having issues at build. Here’s logs when I do ./launcher rebuild app or ./launcher bootstrap app
Logs
I, [2016-11-07T19:31:18.480826 #13] INFO – : > cd /var/www/discourse && su discourse -c ‘bundle exec rake db:migrate’
Failed to report error: Name or service not known 2 Name or service not known subscribe failed, reconnecting in 1 second. Call stack [“/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/redis-3.3.1/lib/redis/connection/hiredis.rb:19:in `connect’”, “/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/redis-3.3.1/lib/redis/connection/hiredis.rb:19:in `connect’”, “/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/redis-3.3.1/lib/redis/client.rb:336:in `establish_connection’”, “/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/redis-3.3.1/lib/redis/client.rb:101:in `block in connect’”, “/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/redis-3.3.1/lib/redis/client.rb:293:in `with_reconnect’”, “/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/redis-3.3.1/lib/redis/client.rb:100:in `connect’”, “/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/redis-3.3.1/lib/redis/client.rb:276:in `with_socket_timeout’”, “/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/redis-3.3.1/lib/redis/client.rb:133:in `call_loop’”, “/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/redis-3.3.1/lib/redis/subscribe.rb:43:in `subscription’”, “/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/redis-3.3.1/lib/redis/subscribe.rb:12:in `subscribe’”, “/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/redis-3.3.1/lib/redis.rb:2760:in `_subscription’”, “/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/redis-3.3.1/lib/redis.rb:2138:in `block in subscribe’”, “/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/redis-3.3.1/lib/redis.rb:58:in `block in synchronize’”, “/usr/local/lib/ruby/2.3.0/monitor.rb:214:in `mon_synchronize’”, “/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/redis-3.3.1/lib/redis.rb:58:in `synchronize’”, “/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/redis-3.3.1/lib/redis.rb:2137:in `subscribe’”, “/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/message_bus-2.0.2/lib/message_bus/backends/redis.rb:304:in `global_subscribe’”, “/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/message_bus-2.0.2/lib/message_bus.rb:513:in `global_subscribe_thread’”, “/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/message_bus-2.0.2/lib/message_bus.rb:461:in `block in new_subscriber_thread’”]
URGENT: could not translate host name “censored_endpoint:5432” to address: Name or service not known
Failed to initialize site default
rake aborted!
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c ‘bundle exec rake db:migrate’ failed with return #<Process::Status: pid 844 exit 1>
Location of failure: /pups/lib/pups/exec_command.rb:108:in `spawn’
exec failed with the params {“cd”=>“$home”, “hook”=>“bundle_exec”, “cmd”=>[“su discourse -c ‘bundle install --deployment --verbose --without test --without development’”, “su discourse -c ‘bundle exec rake db:migrate’”, “su discourse -c ‘bundle exec rake assets:precompile’”]}
f84cadbb62af834c90c52ee65e80d069b259bd28a387223fc2f9d5c608046478
** FAILED TO BOOTSTRAP ** please scroll up and look for earlier error messages, there may be more than one
Here’s app.yml config:
app.yml
## this is the all-in-one, standalone Discourse Docker container template
## After making changes to this file, you MUST rebuild
## BE *VERY* CAREFUL WHEN EDITING!
## YAML FILES ARE SUPER SUPER SENSITIVE TO MISTAKES IN WHITESPACE OR ALIGNMENT!
## visit http://www.yamllint.com/ to validate this file as needed
templates:
## - "templates/postgres.template.yml"
## - "templates/redis.template.yml"
  - "templates/sshd.template.yml"
  - "templates/web.ssl.template.yml"
  - "templates/web.letsencrypt.ssl.template.yml"
## which TCP/IP ports should this container expose?
## If you want Discourse to share a port with another webserver like Apache or nginx,
## see https://meta.discourse.org/t/17247 for details
expose:
  - "80:80"   # http
  - "443:443" # https
params:
  db_shared_buffers: "128MB"
  #db_work_mem: "40MB"
  #version: tests-passed
env:
  LANG: en_US.UTF-8
  UNICORN_WORKERS: 2
  ## TODO: configure connectivity to the databases
  DISCOURSE_DB_SOCKET: ''
  DISCOURSE_DB_NAME: discourse
  DISCOURSE_DB_POOL: 15
  DISCOURSE_DB_USERNAME: discourse
  DISCOURSE_DB_PASSWORD: censored
  DISCOURSE_DB_HOST: 'censored_endpoint:5432'
  DISCOURSE_REDIS_HOST: 'censored_endpoint:6379'
  DISCOURSE_HOSTNAME: 'censored'
  ## Uncomment if you want the container to be started with the same
  ## hostname (-h option) as specified above (default "$hostname-$config")
  #DOCKER_USE_HOSTNAME: true
  DISCOURSE_DEVELOPER_EMAILS: 'censored'
  ## TODO: The SMTP mail server used to validate new accounts and send notifications
  DISCOURSE_SMTP_ADDRESS: email-smtp.eu-west-1.amazonaws.com         # required
  DISCOURSE_SMTP_PORT: 587
  DISCOURSE_SMTP_USER_NAME: censored
  DISCOURSE_SMTP_PASSWORD: censored
  DISCOURSE_SMTP_ENABLE_START_TLS: true           # (optional, default true)
  ## If you added the Lets Encrypt template, uncomment below to get a free SSL certificate
  LETSENCRYPT_ACCOUNT_EMAIL: censored
  ## The CDN address for this Discourse instance (configured to pull)
  ## see https://meta.discourse.org/t/14857 for details
  DISCOURSE_CDN_URL: //censored
volumes:
  - volume:
      host: /var/discourse/shared/web-only
  guest: /shared
  - volume:
  host: /var/discourse/shared/web-only/log/var-log
  guest: /var/log
## Plugins go here
hooks:
  after_code:
- exec:
    cd: $home/plugins
    cmd:
run:
AWS is all set. Neither I think it’s AWS side. Please help :slight_smile:
Fixed on my own.
I thought I had no mistakes from AWS side however my Redis was not configured correctly and I had also used configure endpoint in app.yml. Damn, how did I miss that, it should’ve been primary endpoint :smiley:
I have also added two more lines to app.yml and maybe they were also part of this trick.
Thank you… this worked for me!!
