Problem with text editor on iOS / iPadOS 26 devices
With the rollout of iOS / iPadOS 26 yesterday, we’ve encountered issues with the display and usability of the Discourse text editor.
In some cases, the text editor is pushed past the top of the screen. Sometimes the cursor is just in the wrong place. These issues occur in our forum (tff-forum.de) as well as here in the Discourse meta forum.
According to our tests, the behavior changes depending on the configurable size of the editor window. If you set the editor to a very small size and then click in the text field, the error often occurs when the iOS keyboard appears. If the editor window is set to a large size before clicking into the text field, the editor works as expected.
Here is an example from our forum with the wrong cursor position:
And here an example from the meta forum where the editor is moved out of the screen:
Thank you in advance for every information or suggestions for solving this problem.
Hi, yes sadly ios26 is causing lots of bugs on Discourse and generally speaking many websites on the internets (even apple owned sites).
We are in the process of evalulating the situation and will fix what we can (what is not a plain iOS bug).
I would recommend anyone to delay their update if they can, I can’t imagine apple is not going to release fixes in next weeks for some of these.
See also iOS 26 bugs with fixed position elements in Discourse
