Pyx's Modern Thema
Hey - thanks for the report. I just fixed the profile “Skip to content” error and it should be better now!
In regards to the dropdown I found the line that was blocking it but when I remove it, it looks like this, so I figured it wasn’t worth it to “fix”.
Thanks !!!
I wonder why does it show, I see the fix was to disappear it from the screen hahaha but do you know what is it used for usually ?
Yes, people (myself included) often use tab for easily navigating pages for either convenience or accessibility reasons. For example, if you’re in a form with a lot of inputs, often instead of moving your mouse over to the next box you can press tab and it’ll go to the next one.
Small update released to support the lightbox which now has a scrapped lightbox-style background!
Support for the search UI has also been added
I also made some smaller consistency changes to things like text boxes. Enjoy and let me know your thoughts!
I’m trying to change the color pallet entirely but am unable to do so. Using Vivaldi, also confirmed on Google Chrome
Hi there, are you using a tablet or computer? Working fine (not great but i can click it) for me on Firefox Desktop
Hello, I am using desktop (Windows 11 24H2). I saw earlier posts showing that the theme select works so I don’t know why this occurs over here. I can download Firefox and test that, however.
It’s working fine for me on Chromium (Brave) too, so you can try FIrefox or try disabling all of your extensions and userstyles if present.
Still happens, I don’t know why :sob:
You can try using your phone and making sure Discourse is fully up to date (the theme is always tested against latest tests-passed commit), otherwise I’m not sure what your issue could be, sorry!
the theme look pretty sick honestly thank you for this, do you have a link so i can send it to the admin to add in their theme as well?
thanks
If you mean their site, you can send them the link to this topic and they can click the “Install this theme” button!
oh okay sounds good, i’m on a different community, i will send the link thanks
@darkpixlz is this theme works on ios26.1?
i just check a quick preview of the theme on my phone and wondering if there is any way to make the popup screen blurry like the one from the “search bar “ for the profil, like in the picture, it’s hard to read as you can see, the search bar background is perfectly blur and nice
would be awesome to have the same for on profile, be much easier to read notifications
thanks for your hard work, really like this theme
Historically I haven’t tested against mobile, thanks for letting me know about the issues. I’ll look into fixing the user menu, I guess it’s just broken on anything non-Gecko based.
oh okay, no problem,would be really awesome if you can test it when you have time for iOS, would love to see this theme on my Discourse hub app
thank you mate, really appreciate it🙏🏽
January Update
Hello all! Just another routine cleaning up of the theme and fixing some existing issues and breakage caused by newer Discourse.
Changelog:
  • Fixed the body being ~5px offcenter
  • Fixed the user menu and many dropdowns
  • Corrected composer warnings for new minified core style
  • Added table builder support
  • Numerous post stream improvements [quotes, onebox, nav buttons, codeboxes]
  • Admin and group page fixes
  • User card improvemenets
That’s about it for this update, as per usual let me know if you have questions/comments/concerns!! I’m also working on getting GitHub Sponsors up so you can support the theme if you like it, no news on that for the time being due to Stripe but it’s coming.
hey mate, did you had time to test on iOS 26 yet? still wondering how it will look like
thanks
Hi, I did briefly look at the theme on my iPhone 15 Plus with 26.3 beta something on it. It looks fine and is functional but there is definitely some changes I can make, which I might get around to tonight or sometime this week.
Hi everybody! Back with some more minor changes but the review queue has been fixed and I changed some other minor things.
I also updated the photos in the OP because they were a year old at this point. There’s still more I want to do in the near future (like a mobile layout) so stay tuned for that. I’m also still working on GitHub sposors.
Thanks for your support, enjoy the theme!
