100x75. This one:
Settings… default ones, I didn’t change anything.
100x75. This one:
Hmm… I don’t see any particular issues with it. Testing it with a fresh install seems to work fine.
Does the browser console return any errors? What browser are you using?
IPad and DiscourseHub plus Safari. The console of Safari doesn’t show anything.
Ah, I have a vague idea of what’s causing the issue (related to the dependency). I’ll see if I can replicate the issue on my own devices and get a fix/workaround going.
It seems that the repository is no longer available
Yeah, my GitHub account got terminated without warning. I’ve filed an appeal but don’t know if/when my account and the repo would be restored.
I am not sure the details or pros & cons. But some DeVs have been moving over to gitlab(fixed).
Sorry to hear about your account. Imho a termination of a user account should always come with a reason even if vague.
Woo! It’s been restored!
I wasn’t given a clear reason for it, only that my account was flagged for manual review. I’ll definitely have to consider other alternatives, or at least maintain a private mirror of my repos on my homelab.
I can’t remember how this plugin works. Isn’t there supposed to be a menu option to create a QR code? I checked and made sure the plugin was still installed and enabled yet I don’t see the option
Hmm, that’s odd. Just to double check, the theme component is enabled for all of your themes? It’s a field that I sometimes forget to check myself.
