pokapow
63
Stesso problema qui con Discourse 2.8.0.beta11:
$ rake users:merge['matt','Mateo'] --trace
** Invoke users:merge (first_time)
** Invoke environment (first_time)
** Execute environment
** Execute users:merge
rake aborted!
ArgumentError: ArgumentError
/var/www/discourse/app/services/post_owner_changer.rb:12:in `initialize'
/var/www/discourse/app/services/user_merger.rb:71:in `new'
/var/www/discourse/app/services/user_merger.rb:71:in `change_post_owner'
/var/www/discourse/app/services/user_merger.rb:59:in `block in move_posts'
/var/www/discourse/app/services/user_merger.rb:57:in `each'
/var/www/discourse/app/services/user_merger.rb:57:in `move_posts'
/var/www/discourse/app/services/user_merger.rb:14:in `merge!'
/var/www/discourse/lib/tasks/users.rake:50:in `block in <main>'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/task.rb:279:in `block in execute'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/task.rb:279:in `each'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/task.rb:279:in `execute'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/task.rb:219:in `block in invoke_with_call_chain'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/task.rb:199:in `synchronize'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/task.rb:199:in `invoke_with_call_chain'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/task.rb:188:in `invoke'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:160:in `invoke_task'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:116:in `block (2 levels) in top_level'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:116:in `each'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:116:in `block in top_level'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:125:in `run_with_threads'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:110:in `top_level'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:83:in `block in run'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:186:in `standard_exception_handling'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:80:in `run'
bin/rake:13:in `<top (required)>'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.4/lib/bundler/cli/exec.rb:58:in `load'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.4/lib/bundler/cli/exec.rb:58:in `kernel_load'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.4/lib/bundler/cli/exec.rb:23:in `run'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.4/lib/bundler/cli.rb:484:in `exec'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.4/lib/bundler/vendor/thor/lib/thor/command.rb:27:in `run'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.4/lib/bundler/vendor/thor/lib/thor/invocation.rb:127:in `invoke_command'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.4/lib/bundler/vendor/thor/lib/thor.rb:392:in `dispatch'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.4/lib/bundler/cli.rb:31:in `dispatch'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.4/lib/bundler/vendor/thor/lib/thor/base.rb:485:in `start'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.4/lib/bundler/cli.rb:25:in `start'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.4/exe/bundle:48:in `block in <top (required)>'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.4/lib/bundler/friendly_errors.rb:103:in `with_friendly_errors'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.4/exe/bundle:36:in `<top (required)>'
/usr/local/bin/bundle:23:in `load'
/usr/local/bin/bundle:23:in `<main>'
Tasks: TOP => users:merge
# psql --version
psql (PostgreSQL) 13.5 (Debian 13.5-1.pgdg100+1)
1 Mi Piace
barto_95
64
Ciao,
Sto provando a unire due utenti.
Quando eseguo il comando: rake
Ricevo questo errore:
rake aborted!
ArgumentError: topic
/var/www/discourse/app/services/post_owner_changer.rb:13:in `block in initialize'
/var/www/discourse/app/services/post_owner_changer.rb:12:in `each'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.18/lib/bundler/cli/exec.rb:58:in `load'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.18/lib/bundler/cli/exec.rb:58:in `kernel_load'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.18/lib/bundler/cli/exec.rb:23:in `run'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.18/lib/bundler/cli.rb:483:in `exec'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.18/lib/bundler/vendor/thor/lib/thor/command.rb:27:in `run'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.18/lib/bundler/vendor/thor/lib/thor/invocation.rb:127:in `invoke_command'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.18/lib/bundler/vendor/thor/lib/thor.rb:392:in `dispatch'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.18/lib/bundler/cli.rb:31:in `dispatch'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.18/lib/bundler/vendor/thor/lib/thor/base.rb:485:in `start'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.18/lib/bundler/cli.rb:25:in `start'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.18/exe/bundle:48:in `block in <top (required)>'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.18/lib/bundler/friendly_errors.rb:120:in `with_friendly_errors'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.18/exe/bundle:36:in `<top (required)>'
Non so perché, hai qualche idea sul problema?
