As of Discourse 2.5.0.beta3, site admins can merge non-staff users without needing to access the console. For security, staff users will still need to be merged via the console.
Visit the user admin page, and select “Merge” at the bottom of the page.
Enter the username you want the account to be merged into, and click “Transfer & Delete @username” to start the merge process.
(note: ensure there is no space before/after the comma)
This merges the data of the source user into the target user before it deletes the source user. The content of 45 tables gets merged, so depending on the amount of data associated with the source user this process can take a while.
Plugin authors can hook into the merge process by handling the :merging_users event. I’ve already implemented it for the polls plugin, which merges the votes of the two merged users.
Known problems:
Incoming links that still reference the source user (e.g. https://talk.example.com/t/some-topic/17/3?u=source_username) won’t be associated with the target_user.
A user can have only one shadow user (from the allow anonymous posting feature). So, if both merged users had a shadow user, then the one owned by the source user will be lost… well, it’s still there, but not associated with an existing user anymore.
Thank you for this feature, it is huge for my use case! I am currently porting our forums from phpBB to Discourse and wanted to use SSO via a custom provider. Since we could not easily link SSO accounts to our legacy accounts and works flawlessly!
If anyone else is going to use this make a note of this:
rake users:merge['mattbr_sso', 'mattbr_legacy'] will not work as expected, the SSO will not go through. However:
rake users:merge['mattbr_legacy', 'mattbr_sso'] works perfectly and allows you to migrate all the posts into the SSO account.
When using the ‘User Event’-webhook created or login (or approved?) the duplicates will be existent on a connected site as well and one might want an automatism to clean them up as well, if the connected site supports that.
I haven’t used webhooks yet but plan to. On my connected site (using Discourse as SSO provider) the users are only created at first login for now. + I had duplicate users in my old forum before migrating to Discourse which I was looking forward to consolidate once this feature becomes available.
Yes, it will. I should be able to make this happen for the 2.0 release.
You will have to update the user’s created_at manually if you want to set it to the oldest post. The merge process uses the created_at from either the source or target user – whatever date is earlier.
Any chance the staff action log could better show what happens to users when they are merged? Here’s how it looks now - just shows that system has deleted the user but no context. The details only show some info about the user that got deleted as a result of the merge.
How about adding a staff note along the lines of “Username with email was merged to this account, date”
This is what I did when I was merging accounts manually. Probably more work than a staff action log entry, but might be useful information at some point later.
Is there an easy way to change which email address is primary?
Here’s my use case:
imported user with email user@defunctdomain.com emails from user@fancynewemail.com which creates a staged user. After a few PMs with the staged user, I merge the accounts, but the primary address is still the old one. And from the web interface I can’t change the email in his profile because it’s already taken. By him.
Perhaps this is a bug in the multiple email address model and not a complaint for here.
The simple solution, which took me much to long to come up with, is to delete the old address.
Is there something easier that I should do?
I need to keep the old username with the new email. The staged user is the real problem. Perhaps I should just delete the staged user, but then I don’t have an easy way to reply to them to tell them what happened.
It’s pretty cumbersome to merge[‘newname_newemail’,'oldname_bogusemail"] and then have to do something like
