Recente fout in component $.widget is geen functie
Today I started seeing the banner Your site may not work because theme / component Guild AI DiscoTOC has errors on https://my.guild.ai
The issue appears to be the use of $.widget here:
https://github.com/guildai/DiscoTOC/blob/master/common/header.html#L64
Has something in Discourse changed that would lead to this? What’s your advice to fix the problem?
Thanks!
Looks like your forked this component 2 years ago, so it went stale and incompatible with current Discourse.
You will need to either move to the official component, or rebase your fork.
