בעיות Redis: "Job exception: MISCONF Redis מוגדר לשמור RDB snapshots..."
סיכום מבוסס בינה מלאכותית
The user mreach is experiencing issues with Redis after upgrading Discourse. The error messages indicate that Redis is configured to save RDB snapshots but is unable to persist on disk. This has resulted in commands that modify the data set being disabled.
To troubleshoot, mreach has checked the Redis logs and system resources. The Docker container’s disk usage is at 36%, and memory usage is not excessively high. However, the host system’s htop output suggests that there might be an issue with resource allocation.
mreach is seeking guidance on steps to debug and resolve this issue.
Been having an odd issue since upgrading Discourse.
cd /var/discourse
./launcher enter app
cd /shared/log/rails
tail -f production.log
gives the following ad infinitum:
Job exception: MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
Error connecting to Redis on localhost:6379 (Redis::TimeoutError)
unicorn.stderr.log is full of:
E, [2022-03-01T20:45:20.703541 #65] ERROR -- : reaped #<Process::Status: pid 30842 exit 1> worker=unknown
Detected dead worker 30842, restarting...
Failed to report error: Error connecting to Redis on localhost:6379 (Redis::TimeoutError) 3 Job exception: Error connecting to Redis on localhost:6379 (Redis::TimeoutError)
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/redis-4.1.3/lib/redis/client.rb:126:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/redis-4.1.3/lib/redis.rb:538:in `block in del'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/redis-4.1.3/lib/redis.rb:52:in `block in synchronize'
Clearly it appears to be a problem with Redis and I suspected that it’s being killed off somehow, but it doesn’t seem to be from the kernel log outside of the docker image, however inside the docker image I see:
$ df -h
overlay         157G   53G   97G  36% /
tmpfs            64M     0   64M   0% /dev
tmpfs           3.9G     0  3.9G   0% /sys/fs/cgroup
shm             512M     0  512M   0% /dev/shm
/dev/sda        157G   53G   97G  36% /shared
tmpfs           3.9G     0  3.9G   0% /proc/acpi
tmpfs           3.9G     0  3.9G   0% /proc/scsi
tmpfs           3.9G     0  3.9G   0% /sys/firmware
$ free
               total        used        free      shared  buff/cache   available
Mem:         8167420     3248628      794816        8596     4123976     4634504
Swap:         524284         268      524016
Not great, but not horrible it seems.
Back on the host system htop shows:
Any thoughts on steps to debug/resolve this?
