Remove smtp_should_reject & discourse-smtp-fast-rejection
Continuing the discussion from Seeing smtp_should_reject "400 bad request" failures on bounce processing:
I’m making this topic to summarise some internal discussion we’ve had.
We’ve identified that the codepath in smtp_should_reject is not functioning correctly and causing mail to be rejected in situations where it should not be.
Specifically:
  • bounce messages (having a null envelope-from)
  • forwarded mail to mismatch (the fast-rejection check used the envelope-to, whereas Discourse uses the To/CC headers)
This has caused problems for self-hosters using this:
There’s no interest in maintaining this code so we’re looking to remove it entirely.
Discourse PR:
(this doesn’t remove the endpoint as people’s installs will be trying to hit it - it changes it to always say “do not reject”)
mail-receiver PR:
Both of these fixes appear to work independently of each other (i.e. getting either one will solve the problem) and neither seem to require any effort by people self-hosting beyond updating as normal, is that correct?
This is correct; my motivation is I suspect that people may not update mail-receiver as often as Discourse so I’d like to ensure those people still get the fix.
