Rendering of lines inside "boxed" area changed from multiple lines to a single line
This problem seems to started recently, Installed 3.1.1 (0612f0d5b6). I don’t when exactly it changed but this content is rendered differently now.
There’s the sample
Some text before the box
> Line 1
Line 2
Line 3
This is how it renders here:
Line 1
Line 2
Line 3
However on my site it renders as:
Why is it rendering differently with all the lines in a single line? How do I get it to render like it used to, i.e. how it’s rendering here on a multiple lines
Could you try disabling the traditional_markdown_linebreaks setting on your site?
Yup that fixed it. I had to rebuild the HTML for the changes to take effect. Does that mean I need to only rebuild the HTML for posts which may have been edited after this UI behavior changed or for all posts?
When did this behavior change?
It was a default disabled setting on our install, so perhaps the default was changed or one of your other admins changed the setting.
