tehspaceg
(Geran Smith)
14. Januar 2019 um 17:14
1
I’m testing out the awesome CSP that was added (Mitigate XSS Attacks with Content Security Policy ). I’ve currently had it in report only mode since release, and am seeing a large number of CSP Violation: 'inline' reports on /logs that are violating the script-src.
I’m guessing the best way to avoid those blocking when I move out of report only mode would be to add inline to the content security policy script src option, but since these all appear to be bundled with the main Discourse, is there a safer way to mitigate this?
Backtrace from the largest generator of the errors:
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/logster-1.3.1/lib/logster/logger.rb:101:in `add_with_opts'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/logster-1.3.1/lib/logster/logger.rb:52:in `add'
/usr/local/lib/ruby/2.5.0/logger.rb:536:in `warn'
/var/www/discourse/app/controllers/csp_reports_controller.rb:9:in `create'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.2/lib/action_controller/metal/basic_implicit_render.rb:6:in `send_action'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.2/lib/abstract_controller/base.rb:194:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.2/lib/action_controller/metal/rendering.rb:30:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.2/lib/abstract_controller/callbacks.rb:42:in `block in process_action'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activesupport-5.2.2/lib/active_support/callbacks.rb:132:in `run_callbacks'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.2/lib/abstract_controller/callbacks.rb:41:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.2/lib/action_controller/metal/rescue.rb:22:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.2/lib/action_controller/metal/instrumentation.rb:34:in `block in process_action'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activesupport-5.2.2/lib/active_support/notifications.rb:168:in `block in instrument'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activesupport-5.2.2/lib/active_support/notifications/instrumenter.rb:23:in `instrument'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activesupport-5.2.2/lib/active_support/notifications.rb:168:in `instrument'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.2/lib/action_controller/metal/instrumentation.rb:32:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.2/lib/action_controller/metal/params_wrapper.rb:256:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.2/lib/active_record/railties/controller_runtime.rb:24:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.2/lib/abstract_controller/base.rb:134:in `process'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionview-5.2.2/lib/action_view/rendering.rb:32:in `process'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-mini-profiler-1.0.1/lib/mini_profiler/profiling_methods.rb:78:in `block in profile_method'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.2/lib/action_controller/metal.rb:191:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.2/lib/action_controller/metal.rb:252:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.2/lib/action_dispatch/routing/route_set.rb:52:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.2/lib/action_dispatch/routing/route_set.rb:34:in `serve'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.2/lib/action_dispatch/journey/router.rb:52:in `block in serve'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.2/lib/action_dispatch/journey/router.rb:35:in `each'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.2/lib/action_dispatch/journey/router.rb:35:in `serve'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.2/lib/action_dispatch/routing/route_set.rb:840:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-protection-2.0.3/lib/rack/protection/frame_options.rb:31:in `call'
/var/www/discourse/lib/middleware/omniauth_bypass_middleware.rb:32:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-2.0.6/lib/rack/tempfile_reaper.rb:15:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-2.0.6/lib/rack/conditional_get.rb:38:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-2.0.6/lib/rack/head.rb:12:in `call'
/var/www/discourse/lib/content_security_policy/middleware.rb:12:in `call'
/var/www/discourse/lib/middleware/anonymous_cache.rb:216:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-2.0.6/lib/rack/session/abstract/id.rb:232:in `context'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-2.0.6/lib/rack/session/abstract/id.rb:226:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.2/lib/action_dispatch/middleware/cookies.rb:670:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.2/lib/action_dispatch/middleware/callbacks.rb:28:in `block in call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activesupport-5.2.2/lib/active_support/callbacks.rb:98:in `run_callbacks'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.2/lib/action_dispatch/middleware/callbacks.rb:26:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.2/lib/action_dispatch/middleware/debug_exceptions.rb:61:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.2/lib/action_dispatch/middleware/show_exceptions.rb:33:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/logster-1.3.1/lib/logster/middleware/reporter.rb:31:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/railties-5.2.2/lib/rails/rack/logger.rb:38:in `call_app'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/railties-5.2.2/lib/rails/rack/logger.rb:28:in `call'
/var/www/discourse/config/initializers/100-quiet_logger.rb:16:in `call'
/var/www/discourse/config/initializers/100-silence_logger.rb:29:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.2/lib/action_dispatch/middleware/remote_ip.rb:81:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.2/lib/action_dispatch/middleware/request_id.rb:27:in `call'
/var/www/discourse/lib/middleware/enforce_hostname.rb:17:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-2.0.6/lib/rack/method_override.rb:22:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.2/lib/action_dispatch/middleware/executor.rb:14:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-2.0.6/lib/rack/sendfile.rb:111:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-mini-profiler-1.0.1/lib/mini_profiler/profiler.rb:171:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/message_bus-2.2.0.pre.1/lib/message_bus/rack/middleware.rb:57:in `call'
/var/www/discourse/lib/middleware/request_tracker.rb:180:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/railties-5.2.2/lib/rails/engine.rb:524:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/railties-5.2.2/lib/rails/railtie.rb:190:in `public_send'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/railties-5.2.2/lib/rails/railtie.rb:190:in `method_missing'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-2.0.6/lib/rack/urlmap.rb:68:in `block in call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-2.0.6/lib/rack/urlmap.rb:53:in `each'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-2.0.6/lib/rack/urlmap.rb:53:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/unicorn-5.4.0/lib/unicorn/http_server.rb:606:in `process_client'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/unicorn-5.4.0/lib/unicorn/http_server.rb:701:in `worker_loop'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/unicorn-5.4.0/lib/unicorn/http_server.rb:549:in `spawn_missing_workers'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/unicorn-5.4.0/lib/unicorn/http_server.rb:142:in `start'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/unicorn-5.4.0/bin/unicorn:126:in `<top (required)>'
/var/www/discourse/vendor/bundle/ruby/2.5.0/bin/unicorn:23:in `load'
/var/www/discourse/vendor/bundle/ruby/2.5.0/bin/unicorn:23:in `<main>'~~~~
I can’t recall where we are on logster @pmusaraj ?
Also make sure you update to latest and do a full container rebuild at the command line.
tehspaceg
(Geran Smith)
14. Januar 2019 um 22:13
3
Ahh, does the web upgrade not cover quite as much? I can login tonight and get an upgrade done via SSH.
pmusaraj
(Penar Musaraj)
15. Januar 2019 um 01:55
5
These 'inline' CSP violation errors are in most cases false positives. If you can post the contents of the env tab from the log, that will have some more details, but I’m fairly certain this is coming from an extension.
The vast majority of CSP report violations logged are false positives, and we will shortly turn off reporting by default, because it’s not very helpful. Your best bet in implementing CSP is to visit the site with a few different browsers (Safari, Chrome, Firefox, Edge, and note that IE11 doesn’t support CSP at all) and see if there are errors in the console log.
We still haven’t done this? We need to get this done…
pmusaraj
(Penar Musaraj)
15. Januar 2019 um 02:20
7
I will merge the PR tomorrow.
pmusaraj
(Penar Musaraj)
15. Januar 2019 um 15:44
8
tehspaceg
(Geran Smith)
15. Januar 2019 um 18:52
9
pmusaraj:
I ran the upgrade from the command line and rebuilt my image. Still seeing some inline errors.
Backtrace:
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/logster-1.4.0.pre/lib/logster/logger.rb:101:in `add_with_opts'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/logster-1.4.0.pre/lib/logster/logger.rb:52:in `add'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/logster-1.4.0.pre/lib/logster/middleware/reporter.rb:31:in `call'
Example from env (there are a lot and I can share them all if needed):
|0||
|hostname|gx-discourse-app|
|process_id|26040|
|application_version|978cc0cfca1100391259a5011e36a7a5bd61fcbd|
|HTTP_HOST|gamingexodus.com|
|REQUEST_URI|/csp_reports|
|REQUEST_METHOD|POST|
|HTTP_USER_AGENT|Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:64.0) Gecko/20100101 Firefox/64.0|
|HTTP_ACCEPT|text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8|
|HTTP_X_FORWARDED_FOR|xx.xx.xx.xx, unix:|
|HTTP_X_REAL_IP|unix:|
|CSP Report||
|blocked-uri|inline|
|document-uri|https://gamingexodus.com/t/january-2019-changelog/3762|
|original-policy|base-uri 'none'; object-src 'none'; script-src 'unsafe-eval' 'report-sample' https://gamingexodus.com/logs/ https://gamingexodus.com/sidekiq/ https://gamingexodus.com/mini-profiler-resources/ https://gamingexodus.com/assets/ https://gamingexodus.com/brotli_asset/ https://gamingexodus.com/extra-locales/ https://gamingexodus.com/highlight-js/ https://gamingexodus.com/javascripts/ https://gamingexodus.com/plugins/ https://gamingexodus.com/theme-javascripts/ https://gamingexodus.com/svg-sprite/; worker-src 'self' blob:; report-uri https://gamingexodus.com/csp_reports|
|referrer|https://gamingexodus.com/|
|script-sample|;!function(){var t,e,n,o=0,u=function(t,…|
|violated-directive|script-src|
|line-number|1|
|source-file|https://gamingexodus.com/t/january-2019-changelog/3762|
|1||
|process_id|26019|
|CSP Report||
|blocked-uri|inline|
|document-uri|https://gamingexodus.com/latest|
|referrer||
|script-sample|(function (DOCUMENT, dispatchEvent, CUST…|
|line-number|1|
|source-file|https://gamingexodus.com/latest|
pmusaraj
(Penar Musaraj)
15. Januar 2019 um 19:01
10
Ah, I see that violation in the Chrome console as well (but not on Safari or Firefox) when visiting gamingexodus.com . You can either turn on CSP in full or turn on violation report logging temporarily, Chrome needs one of the two to display more details about the source of the CSP violation.
tehspaceg
(Geran Smith)
15. Januar 2019 um 19:23
11
Just toggled the full CSP on. Oddly enough, I’m not seeing any of the errors now. Do I need to rebuild the Docker image after enabling the full CSP option?
As an aside, I think the two CSP options should be mutually exclusive. You should only be able to select report only CSP, full CSP, or no CSP.
pmusaraj
(Penar Musaraj)
15. Januar 2019 um 19:27
12
No need to rebuild after enabling CSP.
It does look strange at first that these are independent checkboxes, but it might be useful in the future to have separate CSP and Report-only policies, both active (for example to facilitate testing new directives without disabling the current policy).
