Hi guys,
Is it possible to manage ‘reserved usernames’ programmably?
I understand that there is that thing called rails console - would that be where a novice should jump to right away, If it can be done there?
Or else - how do you add many long words to your reserved usernames? Thanks.
Managing ‘reserved usernames’ programmably is possible in Discourse. lejeczek inquired about this, and several users suggested using the rails console to achieve this. While Lilly advised caution due to potential risks, lejeczek is willing to take that risk. As an alternative, pfaffman suggested reverse-engineering the Discourse API and using curl. simon provided step-by-step instructions on how to use the Rails console to update the SiteSetting.reserved_usernames setting, which involves entering the list of usernames separated by pipe characters (|) within quotation marks.
I believe this can be done in the rails console and I think I have an idea of how. But if you are new to working in rails console and are unfamiliar with it, I would suggest learning a bit more about it before doing something like this. Mistakes in rails console can break your forum. For what it’s worth, likely better off doing it manually in the admin UI.
webui will not work for me - I don’t mind broken things, that is what labs are for.
If you’re not familiar with rails, you can Reverse engineer the Discourse API and do it with curl or similar.
Yes, I did this once for a site that had a huge list of reserved usernames. As long as you are aware of the risks of using the Rails console, you can enter it by going to the /discourse directory in your server and running:
./launcher enter app
rails c
From the prompt that appears, run:
You should see output similar to this:
"admin|moderator|administrator|mod|sys|system|community|info|you|name|username|user|nickname|discourse|discourseorg|discourseforum|support|all|here"
That’s the setting’s default value. You will probably want to add the default list to your custom list. Make sure that the entire list is surrounded by quotation marks, with each item separated by a pipe character (|)
Then run:
SiteSetting.reserved_usernames="your|reserved|usernames"
Replace your|reserved|username with your actual list of usernames.
Exit the Rails console by typing exit at the prompt.
