According to this, nothing like this is possible:
Has this changed? Is it possible yet?
Use case: Only allow trusted users who I see fit, able to upload files directly; the rest, unable.
What problem does that solve? Are other users able to include images that are hosted elsewhere and will then be broken images an your site?
It would be something applicable given my unique community/user base.
Giving the uniqueness, you will have better chances funding a custom plugin at the marketplace.
…est-ce que cela a abouti à quelque chose ?
J’ai un cas d’usage : un site communautaire contenant beaucoup de contenu visible publiquement. Cependant, je souhaite uniquement que mes membres payants (via le plugin d’abonnement Discourse, ils appartiennent donc à un groupe spécial) consomment mon espace de stockage via les téléchargements de fichiers.
