Hi,
What do you think about returning something else than a 404 for the deleted subjects ?
I’ve regularly some errors in Google Webmaster Tools when I delete some subjects. Could you send an other error code to indicate the page has been removed?
The discussion revolves around whether deleted subjects in a forum should return a 404 error or another error code, such as 410 Gone. CamilleRoux initially suggested returning something other than a 404 to indicate a page has been removed, citing errors in Google Webmaster Tools. codinghorror and sam argued that a 404 is suitable since the content is deleted. However, CamilleRoux proposed using a 410 Gone, which is supported by omfg and downey who provided references from W3C and Matt Cutts. After re-evaluation, codinghorror agreed that a 410 Gone is more correct for public deleted topics, and riking has implemented the change in a GitHub pull request.
Hi,
What do you mean by hidden subjects? Can you be specific and give an example?
For example this page: https://forum.pragmaticentrepreneurs.com/t/enquete-pour-un-projet-dentreprise/3579 (it returns a 404 currently)
Here is what it looks when you are an admin:
It looks deleted, not just unlisted. That’s why the body content is that pink color – that means deleted.
Yes sorry.
But is it a good idea to send a 404 in this case?
Uh, yeah, since it is deleted.
Completely correct, when you delete a file from a web server you get a 404, this is exactly the same thing conceptually
Why not using a 410 Gone ?
What difference does it make? How does that help anyone? What purpose would such a change serve?
The 410 response is primarily intended to assist the task of web maintenance by notifying the recipient that the resource is intentionally unavailable and that the server owners desire that remote links to that resource be removed
Cutts:
“If a page is gone and you think it’s temporary, go ahead and use a 404. If the page is gone and you know no other page that should substitute for it, you don’t have anywhere else that you should point to, and you know that that page is going to be gone never come back, then go ahead and serve a 410.”
We are re-evaluating this in the light of some 403 problems, I think I am conviced 410 gone is more correct for public deleted topics.. @riking will be working on it.
That change is in:
https://github.com/discourse/discourse/pull/3785/
This snippet is what error codes we’re currently giving out:
The “private (message) topic → 302” seems a bit weird, especially since we give a 403 (same as secure category) for signed-in users.
