I want to install discourse on a VM that is behind a proxy. But I got the certificate error when the script updates gem. The log info is as following:
FAILED
RuntimeError: cd /var/www/discourse && gem update bundler failed with return $
Location of failure: /pups/lib/pups/exec_command.rb:105:in `spawn'
exec failed with the params {"cd"=>"$home", "hook"=>"web", "cmd"=>["gem updat$
03ddefcc67a4576532eaac06b03d799e957dbdb8530cff6ff49331e6a087b3e7
FAILED TO BOOTSTRAP
detailed info is as following:
[2015-07-22T10:16:57.849945 #45] INFO -- : > cd /var/www/discourse && gem update bundler
ERROR: While executing gem ... (Gem::RemoteFetcher::FetchError)
SSL_connect returned=1 errno=0 state=SSLv3 read server certificate B: certificate verify failed (https://api.rubygems.org/specs.4.8.gz)
I guess that’s because this host is behind a proxy, and the proxy have replaced the certificate. I was encountered the similar error in git command and I have to modify the launcher script to add
git config --global http.sslverify false
to bypass certificate verify. How could I by pass certificate verify for this gem update as well?
I suggest changing the source of gem command to plain http rubygems (add http rubygems one, remove HTTPS) with gem sources command, and changing it too on the first line of Discourse Gemfile.
First and foremost don’t forget to update & upgrade your ubuntu machine.
If it persists let’s get dirty:
./launcher enter app gem sources --add http://rubygems.org gem sources --remove https://rubygems.org
Now you can try to install a random gem just to see if it works, let’s try sinatra: gem install sinatra
If it works we need to change Discourse Gemfile: vim /var/www/discourse/Gemfile
and try to install.
Since my docker-fu ain’t that strong, I’m not sure if ./laucher bootstrap will just reset our modified Gemfile.
[2015-07-24T01:53:18.299109 #45] INFO – : > gem sources -a http://rubygems.org/
ERROR: While executing gem … (Gem::OperationNotSupportedError)
Not connected to a tty and no default specified
@riking
Could you be more specific about how to install CA certificate to container? I’m not quite familiar to docker and ruby.I found a stackoverflow discuss [docker container ssl certificates ][1]
docker run -v /host/path/to/certs:/container/path/to/certs -d IMAGE_ID "update-ca-certificates"
So I run
sudo docker run -v /etc/ssl/certs/:/etc/ssl/certs/ -d samsaffron/discourse:1.0.8 "update-ca-certificates"
Now I got the following error:
Message from syslogd@apc-lgmdcapp210 at Jul 24 05:12:27 …
kernel:journal commit I/O error
Error response from daemon: Error running DeviceSuspend dm_task_run failed
Hey guys,
I’v updated the image to 1.0.12, now I get this error:
[2016-03-28T09:00:51.116726 #39] INFO -- : > cd /var/www/discourse && gem update bundler
ERROR: While executing gem ... (Gem::RemoteFetcher::UnknownHostError)
no such name (https://api.rubygems.org/specs.4.8.gz)
Is it because the proxy issue? How can I config the proxy info for a ruby command in a docker?
