Running Discourse in an iframe
I’m looking to gain more experience with Angular and Node (as that is what is being used in my work place) and want to use a website idea I’ve been shelving for quite a while now. Initially I expected to simply run Discourse in an iframe in the Angular app, but it’s never that easy.
Are there very clear reasons not to meddle with the X-Frame-Options, including loosening it to ALLOW-FROM? What would be the most elegant approach to integrating Discourse in an Angular SPA or am I barking up the wrong tree?
Discourse living in an iframe isn’t a common use. You can try, of course, but it’s not something we recommend.
How would one go about changing the default X-Frame-Options setting within Discourse? I’ve been trying to update
Rails.configuration.middleware.use Rack::Protection::FrameOptions
To
Rails.configuration.middleware.use Rack::Protection::FrameOptions, :frame_options => "ALLOWALL"
in
config/initializers/011-rack-protection.rb
and then restarting the unicorn, but that doesn’t seem to be what I’m looking for (it doesn’t work).
I think it’s a matter of just adding the host in /admin/customize/embedding instead of messing with the code to get this header.
Ah, my bad, for some reason I assumed that was only for embedding comments. I will have a look, thank you.
That will add the header x-frame-options:ALLOWALL on the /embed route that will allow you to test your setup.
If, after testing you still wanna go with this iframe route, I guess adding this header in a reverse proxy is the easiest way.
Well, another issue is the URL not updating if the user switches views in the iframe. Which would raise another issue with document.getElementById("iframe_id").contentWindow.location.href not being available cross origin. It might be a better idea to serve Discourse out of a folder and keep everything on the same origin.
YES!
What everyone does is having mainapp.com and discourse.mainapp.com.
You just add the same font, background, header, etc and it’s the same site for your users.
Those are not on the same origin :yum: but I can compromise and split the site into 2 apps, the Angular app as the landing page and the Discourse app as the community solution supporting it. I was looking to tightly integrate the too, but might even be a better idea to keep them separate and access the Discourse data I’m after through the API.
Thanks Falco
