Currently when trying to search using firefox I get an error in the javascript console:
If I do the same search not logged in no error in console and it works as expected:
Edit: this also seems to be broken for other browsers when logged in.
I can’t reproduce this issue, is it still happening for you?
Yes this is still the current state I am in.
I am a bit surprised you cannot reproduce this using since I see this behavior using a brand new firefox profile and a new Chrome profile. If I figure out something on my end ill update the topic.
Is it possible one of my drafts is causing this problem?
Update: this may be a red herring, when I do a ctrl-shift-r and try search I do not get that error in the console.
I can reproduce on Android Chrome app. If I log out search works. Logged in it just hangs or claims it can’t find anything or something went wrong.
The errors I did see in console seem to be related to plugin translate.
Search is functioning properly on tests passed in my instances.
My SS console errors
I couldn’t repro either, but thanks for logs @dubwoc, I have a fix incoming. Will post an update here, once it’s landed.
It’s happening for me on Chome Andoid and Linux.
It feels like it’s because of the AI search.
Sorry. All of that is before doing a search.
I also saw something about ai search discoveries
The fix should now be live and the issue should be resolved. Please let me know if you are still seeing this issue.
It is indeed fixed, thank you @keegan for the quick response and to @pfaffman and @Heliosurge for confirming the issue!
This topic was automatically closed after 3 days. New replies are no longer allowed.
