Kristian
(Kristian)
30. April 2020 um 09:24
1
My digitalocean discourse droplet can’t send mails. The error I get is:
Delivered mail d8f9bf03-a3ce-4b42-8226-fc4f40a9c724@foo.barbar.com (5099.4ms)
Job exception: 504 5.7.4 Unrecognized authentication type [BL0PR0102CA0036.prod.exchangelabs.com]
My settings are:
DISCOURSE_SMTP_ADDRESS: smtp.office365.com
DISCOURSE_SMTP_PORT: 587
DISCOURSE_SMTP_USER_NAME: foo@bar.com
DISCOURSE_SMTP_PASSWORD: "mypassword"
DISCOURSE_SMTP_ENABLE_START_TLS: true # (optional, default true)
I have tried telnet from the droplet and it gives no errors:
telnet smtp.office365.com 587
What could be the problem? I have tried the smtp settings combination locally from python and it works so I assume that’s not the problem.
mik
30. April 2020 um 10:34
Hi,
Try to add:
DISCOURSE_SMTP_AUTHENTICATION: login
And at end of app.yml:
- exec: rails r "SiteSetting.notification_email='foo@bar.com'"`
1 „Gefällt mir“
Kristian
(Kristian)
30. April 2020 um 11:27
3
Hi mik
The exec statement fails:
FAILED
Pups::ExecError: rails r "SiteSetting.notification_email='foo@bar.com'"` failed with return #<Process::Status: pid 2229 exit 2>
exec failed with the params "rails r \"SiteSetting.notification_email='foo@bar.com'\"`"
9628e31c775b74ad0f3a555b6af27701aa40b1f8b86419fa44a7c389cc5e34ae
Kristian
(Kristian)
30. April 2020 um 12:28
4
Update leaving out the exec command but adding:
does not produce return an error I only get:
Delivered mail be6d8718-5445-48cc-a120-6d6d1eab9eb7@discourse.bar.com (4307.2ms)
But I still don’t get an email in my inbox (I checked the spam folder)
mik
30. April 2020 um 13:34
5
You can try this in order to try to find the good configuration and perhaps have some error message:
docker exec -t -i id_of_your_container /bin/bash
Then inside the container:
apt install s-nail
echo "This is the message body and contains the message" | s-nail -r "foo@bar.com" -s mysubject -S "smtp=smtp.office365.com:587" -S smtp-use-starttls -S smtp-auth=login -S smtp-auth-user="foo@bar.com" -S smtp-auth-password="xxxxxxxx" -S ssl-verify=ignore youremail@example.com
You can change the different value (ie : smtp-auth=login ) to try to find the good one. And perhaps you will have more precise error message.
2 „Gefällt mir“
Kristian
(Kristian)
30. April 2020 um 15:01
6
This worked and I got the mail! I had to change the smtp-auth-password=“xxxxxxxx” to single quotes though since my password starts with an ‘!’.
The only difference I can see to my config is this flag:
Do I have to add that too?
Thanks for your help!
mik
30. April 2020 um 15:14
7
Try to add:
DISCOURSE_SMTP_OPENSSL_VERIFY_MODE: none
In your config, it is the same as ssl-verify=ignore .
Kristian
(Kristian)
30. April 2020 um 15:59
8
No errors but still no email in the inbox To recap, this is my config now:
DISCOURSE_SMTP_USER_NAME: info@foo.com
DISCOURSE_SMTP_PASSWORD: 'xxx'
mik
30. April 2020 um 16:31
9
Please try to add this again (it is the same as “-r” option in the s-nail command line test :
The email must be the same as your account.
And check the indentation in the file app.yml, and do not forget the “-” at the beginning. There is 2 space then the “-” then a space then “exec…”
Capstan
(William Carter)
3. Mai 2020 um 01:34
10
I’m having this problem also. I spun up a droplet with Discourse on Digital Ocean as well. I used the “sudo ./discourse-doctor” command after trying all of these suggestions and rebuilding each time ( sudo ./launcher rebuild app).
504 5.7.4 Unrecognized authentication type [BL0PR01CA0015.prod.exchangelabs.com]
s-nail from within the container did work for me also, no problem. And I tried it without the “-S ssl-verify=ignore” clause, worked fine. Can someone verify that what gets installed on the digital ocean droplet does send email correctly?
riking
(Kane York)
3. Mai 2020 um 06:32
12
Find out from your mail admins what the valid values of smtp_authentication are, and set DISCOURSE_SMTP_AUTHENTICATION to one that works.
1 „Gefällt mir“
Kristian
(Kristian)
3. Mai 2020 um 09:14
13
Thanks for all the help, I have given up and switched to another forum solution.
1 „Gefällt mir“
Capstan
(William Carter)
3. Mai 2020 um 14:38
14
It is Microsoft, their instructions are as follows, no smtp_authentication is specified;
Do you not support this kind of server? Can you simply make an account, connect to it, and tell us what the settings should be?
Das hat mein Problem gelöst, danke!
1 „Gefällt mir“
