That definitely clears up some issues for people adding Discord notifications using chat integration. I had just updated the instructions now because of Discord’s latest changes.
For those afraid of steps, there’s only 7 now because the warning counted as a step
Hello, I can’t post Discourse messages in a Discord forum thread. Would you have a solution for me?
I get the error discoursechatintegration://:ProviderError when I try to send a test message. (I did add the thread ID at the end, from the address ?thread_id=111111111). I tried sending test messages with the discohook.org tool and had no problems, so I think my settings are fine ?
Note that the category references are rendered as <span class=hashtag-icon-placeholder"></span>Category-Name</span> — literal HTML, and also unbalanced spans.
(Because the content of the message I quote obliquely references this plugin: This was me gently encouraging a new forum user to choose the most specific category, so that this plugin would know to send a notification. I’m not reporting the behavior of not sending notifications to discord when a topic is newly moved into a watched category as a bug; that’s a reasonable limitation IMHO.)
Not a big deal but I thought I’d mention it since I noticed it.
This has been fixed as of the following Discourse update:
Specifically, syncing topics and posts from Discourse to Discord forums via the chat-integration plugin should now create a new forum post in Discord.
Note that with this integration, new topics and replies will appear the same in the forum channel, and you will need to open each forum thread to see the post content.
