Sharepoint ל-Discourse
Is there any available tools to migrate from sharepoint discussion board to discourse?
There does not appear to be a sharepoint importer in scripts/import_scripts. If you are a programmer, you can likely use one of the existing import scripts as a model; I wrote several importers before I really learned Ruby (my Programming Languages professor was right that I could pretend to know a language that I didn’t, except, perhaps, for javascript).
It appears that Export sites, lists, or document libraries in SharePoint Server - SharePoint Server | Microsoft Learn might be of some help in figuring out how to export the data. What is most desirable is a full dump of the SQL database, not Excel files.
If you’re not a programmer and don’t have access to one, you can ask in marketplace or see Redirecting….
