Código corto para insertar botón de unirse/salir del grupo en una publicación
To integrate group memberships more fluidly into the community-building aspects of Discourse posts, it would helpful to have a short-cut for inserting the join group interface directly into any post.
For example, it could be a code added to the end of a group name, e.g. @volunteers_group:join. Whether the button appears as +Join or +Request to join or -Leave will depend on the users current membership and group security.
The button should be displayed with the group name, as well as a note indicating what priviliges joining that group offers, i.e. is it a public/private group; which categories have added visibility.
The feature would give administrators of projects the ability to bootstrap teams very efficiently.
5 Me gusta
Can’t you just send out invites which contain a group membership? As I understand it, invites work to add existing users to a group, correct @techapj?
2 Me gusta
I think the use case is around self service, the groups page is kind of hidden, it would be a fairly complex change permission wise to support the proposal though
1 me gusta
Here’s an example post.
Welcome to the conference!
There are three content streams being featured, but each attendee should pick only one to focus on. Select which group to join below. We are also looking for 5 jury members to choose winning projects. Apply if interested.
Stream 1: Fruit – JOIN
Stream 2: Computers – JOIN
Stream 3: Waterfalls – JOIN
Apply to join the conference jury – APPLY
Thank you
Dr. Neylor
4 Me gusta
Currently the only way to add existing user to a group via invite is by using Invite Link (prepared via Invite Token), more details here:
The Invite Link can serve this case because the user will only be added to a group if they click on that link.
5 Me gusta
So you’re saying that there is already a method in the codebase for generating this link, contrary to @sam’s concern, and it’s mostly a matter of building a new UI around generating the link?
It’s not exactly what you are looking for and what Sam is proposing, it’s kind of a workaround which you can use if it works for you.
3 Me gusta
I think that “Stream 1…” example would still work pretty well if those “JOIN” buttons were appropriately styled and just linked to the group page. I strongly doubt you’d lose many people in the onboard funnel with that extra click.
Although far from a perfect equivalent, I do hate it when websites use that interactive “follow us” Twitter widget which asks me to follow them immediately instead of taking me to their Twitter stream so I can see if I’m actually interested in what they’re putting out.
2 Me gusta
Sort of, we should allow for /groups?only-show-group=bla which would be a very easy change and take away a ton of the current noise of simply linking to the groups page. (eg: what if there are 100 groups)
6 Me gusta
Maybe, the equivalent for topics is categories and tags.. should groups also have categories and tags?
2 Me gusta
Resucitando esto, he buscado y no he encontrado una buena opción: queremos centralizar muchas configuraciones del sitio en un solo lugar.
una selección de sí/no ‘notifíqueme si el chatbot menciona al grupo @xyz’ que se vincula al manejador de unirse/salir del grupo. Enlazarse a groups/?showonly= es lo siguiente mejor, pero ‘unirse’ a un ‘grupo de configuración’ no es intuitivo para muchos de nuestros usuarios.
Me gustan las ideas discutidas en este tema. Los grupos ciertamente podrían usar algo de atención, aunque no es un área de enfoque para el equipo en este momento. ¡No dude en implementar mejoras como un componente temático para probarlo!
Una idea que se me ocurrió es que podríamos agregar botones de Unirse/Salir en la tarjeta de usuario para grupos que permitan a las personas unirse y salir libremente.
De esa manera, la publicación de ejemplo que @trudat escribió anteriormente podría reescribirse, por ejemplo:
2 Me gusta
