Show latest PMs when searching in:private @usermention
I used to be able to type in something like the following, and it would show the most recent PMs between me and that person:
Maybe this was never an intentional feature, but this no longer works. I now need to type in a word for the search to work.
Should this work @sam?
Hmm … this extends beyond …
@sam #support
Does not work as well… I wonder if something regressed here, will bookmark…
@erlend_sh any idea when it’s started ?
Wild guess: FIX: Strip zero-width characters from search terms. · discourse/discourse@684b05f · GitHub
Nahh I think this also relates to magic @ handling @cpradio added a while back there was another topic about it.
I’m not sure why, all I did was permit the auto-complete to show. It still fills out the input box the same, just less user interaction. The above scenarios fail to return anything even if I type a space after auto-complete, which either means, it isn’t sending the query, or the server-side is failing to return anything/process the search (which wasn’t touched with auto-complete)
It could be though, but I don’t recall doing any trim or what-not, but that was months ago.
No worries, I will debug this … got it bookmarked.
