Slack: Post chat snapshot to Discourse
Continuation of GitHub - discourse/discourse-slack-official: DEPRECATED: Official Slack integration for Discourse · GitHub
Summary
Take a snapshot of a discussion in Slack and post it as a topic in Discourse. The output should be a cleanly formatted chat transcript. The average snapshot would be between 5-100 messages long. Also see “Wisemonk - a Slack bot to move discussions from Slack to Discourse”.
Use Discourse as your “long term memory” for Slack conversations worth remembering.
Core functionality
  1. Type a command like /topic last:50 category:staff in Slack.
  2. @system (or other designated user) create a new topic in the #staff category. This topic will contain your 50 last Slack messages (in plaintext or minimal Markdown).
Stretch goals
  • Set custom timegap for the snapshot: from:15:35-16:10 (might be tricky due to timezone differences)
  • Ignore messages from selected users in snapshot: ignore:bob,sara
  • Post as the user who issues the command via Slack
  • Open pre-filled topic in browser instead of posting directly
  • A graphical interface for posting snapshots. Might be possible to do something using Slack Buttons.
3 个赞
What about a “pull” approach instead of “push”?
Workflow:
  1. Copy link to particular slack message
  2. Paste it into discourse
  3. Onebox has settings for authentication with private slack instances to feature message
  4. Onebox appends something like [before:0,after:0] to the end of the link, indicating that it’s going to suck in 0 messages before and after the link (maybe site settings to control those defaults?)
  5. User can edit the plaintext to add more messages before and after the post
I think this would be easier to reason about, and allow pasting slack messages as a new topic or inside any post…
I’m calling it “Onebox” above, but maybe its more of a hybrid onebox/plugin thing… not sure the implementation, just using it as a shorthand for the UX.
4 个赞
Certainly worth considering. @vinothkannans is gonna be working on this, so if our initial plan fails, he can try the “pull approach” instead.
1 个赞
Just a quick thought on this - it’s quite a security risk to add oneboxing capability to slack messages… The links to messages on slack are essentially
/channel_id/message_timestamp
so not exactly hard for someone to guess. Then if they wanted to read your private Slack messages they could make requests to something like
https://meta.discourse.org/onebox?url=myorg.slack.com/archive/channel_id/message
Not necessarily a deal-breaker depending on the organisation, but something to bear in mind if someone does implement this “pull approach”. Should be reasonably safe in a login_required discourse instance.
6 个赞
Completed:
2 个赞
