Slack threads and chat integration plugin transcripts
For ‘Private Channels’ you need to add the groups:history scope. For “Direct Messages” you need to add the im:history scope. You will need to ‘reinstall’ the app for changes to scopes to take effect (Slack’s UI should have prompted you to do this).
Are you seeing anything at /logs when the errors occur?
2 Me gusta
I tried adding these scopes, and reinstalling:
groups:history
im:history
mpim:history
Still getting that 422, but don’t see anything obvious in the Discourse logs in the admin panel (this is a hosted instance, so I don’t have direct access to other logs).
1 me gusta
I used the /discourse post command from a public channel to great effect… but threads are now more common in many channels than main channel conversations, so still hopeful that some day this will work in a thread…
Update: w00t! just tried it again and it worked!
/discourse post https://ourdomain.slack.com/archives/C0591LA4X/p1529529151000359?thread_ts=1529528304.000177&cid=C0592LA4X
as did:
/discourse post thread https://ourdomain.slack.com/archives/C0592LA4X/p1529528304000177
Another update: I was also able to post a thread from a private channel. :tada:
9 Me gusta
I got an error when using post transcript in a public channel:
	"message": "Job exception: undefined method `[]' for nil:NilClass\n",
	"progname": null,
	"severity": 3,
	"backtrace": "/var/www/discourse/plugins/discourse-chat-integration/lib/discourse_chat/provider/slack/slack_message.rb:38:in `block in text'\n/var/www/discourse/plugins/discourse-chat-integration/lib/discourse_chat/provider/slack/slack_message.rb:30:in `gsub'\n/var/www/discourse/plugins/discourse-chat-integration/lib/discourse_chat/provider/slack/slack_message.rb:30:in `text'\n/var/www/discourse/plugins/discourse-chat-integration/lib/discourse_chat/provider/slack/slack_message.rb:62:in `processed_text_with_attachments'\n/var/www/discourse/plugins/discourse-chat-integration/lib/discourse_chat/provider/slack/slack_transcript.rb:155:in `block in build_slack_ui'\n/var/www/discourse/plugins/discourse-chat-integration/lib/discourse_chat/provider/slack/slack_transcript.rb:155:in `map'\n/var/www/discourse/plugins/discourse-chat-integration/lib/discourse_chat/provider/slack/slack_transcript.rb:155:in `build_slack_ui'\n/var/www/discourse/plugins/discourse-chat-integration/lib/discourse_chat/provider/slack/slack_command_controller.rb:95:in `block in process_post_request'\n/var/www/discourse/lib/scheduler/defer.rb:70:in `block in do_work'\n/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rails_multisite-2.0.4/lib/rails_multisite/connection_management.rb:63:in `with_connection'\n/var/www/discourse/lib/scheduler/defer.rb:68:in `do_work'\n/var/www/discourse/lib/scheduler/defer.rb:59:in `block (2 levels) in start_thread'",
	"count": 9,
	"env": {
		"message": "Running deferred code 'Processing slack transcript request'"
	"protected": false
1 me gusta
Hello, did you managed to fix this? I have the same one.
To close the loop here - @mbugowski kindly contributed a pull request to fix the issue:
@tony612 if you update to the latest version it should now work.
5 Me gusta
Slash commands now work in Slack Threads! See :point_down:t3:
Any chance we could see support for a slash command within a thread that posts a transcript? :crossed_fingers:t3:
6 Me gusta
I really want this to be true because it would make my life so much easier, but I don’t see anything about it in the Slack API documentation. I wonder if they gave giphy special alpha-testing access? Do you see documentation that I don’t?
More information, possibly: Today at work, one person in a thread complained about slack not allowing /giphy in threads and posted an image of slack telling them that it wasn’t supported in threads, and another person used /giphy successfully, in the same thread. Seems like there might be some A/B testing going on here.
1 me gusta
Good news! I just merged a change to the plugin which adds support for Slack’s “Shortcuts” API. Now you can hit the on a thread, click “Post to Discourse”, and you’ll be given a button which takes you straight to Discourse. No more fussing with slash commands or thread permalinks!
To get this working, you’ll need the latest version of the chat-integration, and you’ll need to modify your Slack app using this new step of the setup
As always, let us know if you have any feedback :slight_smile:
cc @mcwumbly @galligan @mcdanlj
9 Me gusta
:star_struck::star_struck::star_struck:
Incredible!
I tried to add this functionality just now and unfortunately got an
Error: unable to fetch channel history from Slack
I tried this on our newest Slack message.
Have you followed all the setup instructions in this topic. In particular, have you given the bot all the necessary scopes?
I found the problem! Our Chat Integration App wasn’t in the channel I was trying to post from. After inviting the app to the channel, I was able to post a transcript. Thank you.
  • Is it possible to automatically add the Chat Integration App in every Slack channel automatically, now and in the case of any new channel created in the future?
  • Changing the “Continue on Discourse” button text to something more like “Create Transcript” or the Name of the shortcut (default “Post to Discourse” but changeable) would make sense from a UX perspective, given that not all Discourse sites call themselves Discourse
2 Me gusta
Unfortunately I don’t think so, but I’d love to be wrong on that. I will look into whether we can improve the error message here so it gives you instructions on how to add the bot to the channel.
:+1: good point. We can certainly update the default to remove the word ‘Discourse’. But in the meantime, you should be able to search for “Continue on Discourse” in the admin panel and change it to whatever you like: Customize text in Discourse
Edit: default button text is now Continue on Forum
4 Me gusta
Seguí todos los pasos descritos en el hilo de Slack. Agregué todos los ámbitos descritos allí (incluso agregué algunos adicionales) e invité a la aplicación a los canales relevantes.
El problema es que en el 1% de los casos parece funcionar, mira aquí:
Pero en el 99% de los canales públicos, obtengo el error: “Error: no se pueden obtener usuarios de Slack”
Y en los mensajes directos: “Error: no se puede obtener el historial del canal de Slack”
1 me gusta
