[Résolu] URLs incorrectes/encodées en dur dans les mentions d'utilisateurs et de groupes (installation dans un sous-dossier)
Hi,
Since one of the latest updates, the URL on tags is no longer correct. Our development zone that is running on a previous version has the correct URLs.
See screenshots:
Those URLs should be /community/forum/u/klortie and /community/forum/groups/private-support.
All other URLs seem to work correctly, for example:
3 « J'aime »
Can confirm this has regressed on my subfolder install. User and group links do not include the subfolder.
5 « J'aime »
We should fix this @pmusaraj
3 « J'aime »
This should do it: FIX: user and group mentions in subfolder installs · discourse/discourse@421d47d · GitHub
7 « J'aime »
Confirmed fix is good. You’ll need to rebuild the html on any broken posts, but once done URLs work as expected.
6 « J'aime »
Thanks a lot for the quick fix!
I believe that it is:
./launcher enter app
rake posts:rebake
to rebuild all posts?
Yep, if this affected lots of posts, that’d be the way to go. If just a few, I’d do it by hand by clicking the “show more” button, then the “post admin actions” wrench, and finally “rebuild html”.
2 « J'aime »
Thanks, that makes sense. We’ll fix the broken posts that created problems for some users that way and then let the rake posts:rebake command run in the background for everything else.
3 « J'aime »
I confirm the that the issue has been fixed.
5 « J'aime »
This topic was automatically closed after 42 hours. New replies are no longer allowed.
