Spaces adjacent to emoji text?
The discussion revolves around emoji rendering issues in Discourse’s latest version (1.9.0.beta4), particularly when colons are adjacent to text without spaces. appcomq reports that emojis like :relaxed: fail to render if no space precedes or follows the colon, citing poor user feedback (99% negative) on the new emoji UI. j.jaffeux questions whether this was previously functional and requests clearer bug reports — specifically: what’s broken, expected behavior, and reproduction steps. He suspects the issue may not be tied to the emoji picker and advises upgrading to master for recent fixes. appcomq clarifies the bug: :disappointed_relieved: fails without surrounding spaces. codinghorror confirms this is intentional design — Discourse does not support emoji syntax embedded within text (e.g., rand omtext:smile: or :smile:randomtext) to avoid conflicts with programming syntax. schungx questions this design choice, noting that most forums aren’t programming-focused and such colon usage is rare outside emojis, suggesting it should be a configurable site setting. The thread highlights tension between usability expectations and technical design constraints.
I have up to last version , There was a lot of user bugs in the latest post.
eg:
TEST:relaxed::relaxed:
Are you sure it used to work ?
I can reproduce on an instance with Discourse 1.8.3.
@zogstrip is it the issue you told me weeks ago, about the difference between french/english where one expects space before : and the other doesn’t?
now version is 1.9.0.beta4
The error occurred in the new version emoji UI, and The new UI is very friendly to the phone.
99% User feedback is bad:joy:
I’m fully ready to fix things, but I can’t fix anything with this kind of feedback, and this is not the feedback we have from other sources. So please tell me:
  • what’s not working
  • what’s the expected behaviour
  • how to reproduce it
Concerning your first question, I might be wrong but I’m almost certain it’s not related to the emoji picker (and it doesn’t mean we shouldn’t fix it).
Also are you exactly on the 1.9.0.beta4 tag commit, or on master ? If not on master you might want to upgrade as A LOT of fixes have been issued concerning the emoji picker since this tag.
4 إعجابات
hello, I use test-passed.
what’s not working
how to reproduce it
If there is no space at the end:disappointed_relieved:
canot show emoji.
That is by design. There is no expectation that
randomtext:smile:
should work.. nor
:smile:randomtext
4 إعجابات
I wonder why. This is probably done to prevent conflicts with program code for languages which use a lot of.colons.
Many forums, however, has nothing to do with programming. So it is very rare for colon usage like this to be valid other than an emoji.
At least it should be a site setting…
