SSO and Discourse Consulting
Hidetaka_Ko is seeking advice on implementing Single Sign-On (SSO) between their existing Rails application and a Discourse forum hosted on a subdomain. They have successfully set up the forum but are unsure how to integrate user authentication from their Rails app to automatically log users into the Discourse site after logging in. They describe the current flow—where users are redirected to the Rails site to log in and then should be returned to the Discourse forum—and ask what steps are needed to achieve seamless SSO. They offer to share code or grant access to their repository for further assistance.
・What would you like done?
I have an existing rails app that is using session controller as it’s user authentication.
https://www.diverseas.com/
I added a discourse forum and everything went smoothly and it resides on a subdomain.
https://forum.diverseas.com/
I have read the post at Setup DiscourseConnect - Official Single-Sign-On for Discourse (sso)
but still don’t know what to do with the session controller once the user logs in on the existing rails site.
Currently this is the process as I understand it:
Step1: User hits Discourse forum on subdomain. User needs to login so clicks login button.
Step2: User is sent to the login page on the existing rails site.
Step3: User logs in on rails site.
Step4: User should be redirected to discourse forum subdomain logged in. My question is - What do I need to to do to make it so that when a user logs in for these steps?
I can show you my code or invite you to our repo if you want.
・When do you need it done?
Flexible
