I tend to use this field quite frequently, and often entering the same text.
I was wondering whether you may consider providing a drop down menu, populated with configurable items for this.
There would still be the need for free text potentially as well as the option to select from a drop down menu. Perhaps one default option could be “Other” or “Free Text”, which would then enable the existing functionality.
Just a thought.
