Opschorting e-mails mislukken met 'undefined method 'topic', andere e-mails werken prima
3.1.0.beta3
When a user is suspended, the email to them is not sent, and the error below is logged. All other email is delivered normally.
Job exception: undefined method 'topic' for nil:NilClass
Backtrace
/var/www/discourse/app/jobs/regular/user_email.rb:116:in `message_for_email'
/var/www/discourse/app/jobs/regular/user_email.rb:76:in `send_user_email'
/var/www/discourse/app/jobs/regular/user_email.rb:39:in `execute'
/var/www/discourse/plugins/chat/lib/chat/user_email_extension.rb:6:in `execute'
/var/www/discourse/app/jobs/regular/critical_user_email.rb:12:in `execute'
/var/www/discourse/app/jobs/base.rb:249:in `block (2 levels) in perform'
rails_multisite-4.0.1/lib/rails_multisite/connection_management.rb:80:in `with_connection'
/var/www/discourse/app/jobs/base.rb:236:in `block in perform'
/var/www/discourse/app/jobs/base.rb:232:in `each'
/var/www/discourse/app/jobs/base.rb:232:in `perform'
sidekiq-6.5.8/lib/sidekiq/processor.rb:202:in `execute_job'
sidekiq-6.5.8/lib/sidekiq/processor.rb:170:in `block (2 levels) in process'
sidekiq-6.5.8/lib/sidekiq/middleware/chain.rb:177:in `block in invoke'
/var/www/discourse/lib/sidekiq/pausable.rb:134:in `call'
sidekiq-6.5.8/lib/sidekiq/middleware/chain.rb:179:in `block in invoke'
sidekiq-6.5.8/lib/sidekiq/middleware/chain.rb:182:in `invoke'
sidekiq-6.5.8/lib/sidekiq/processor.rb:169:in `block in process'
sidekiq-6.5.8/lib/sidekiq/processor.rb:136:in `block (6 levels) in dispatch'
sidekiq-6.5.8/lib/sidekiq/job_retry.rb:113:in `local'
sidekiq-6.5.8/lib/sidekiq/processor.rb:135:in `block (5 levels) in dispatch'
sidekiq-6.5.8/lib/sidekiq.rb:44:in `block in <module:Sidekiq>'
sidekiq-6.5.8/lib/sidekiq/processor.rb:131:in `block (4 levels) in dispatch'
sidekiq-6.5.8/lib/sidekiq/processor.rb:263:in `stats'
sidekiq-6.5.8/lib/sidekiq/processor.rb:126:in `block (3 levels) in dispatch'
sidekiq-6.5.8/lib/sidekiq/job_logger.rb:13:in `call'
sidekiq-6.5.8/lib/sidekiq/processor.rb:125:in `block (2 levels) in dispatch'
sidekiq-6.5.8/lib/sidekiq/job_retry.rb:80:in `global'
sidekiq-6.5.8/lib/sidekiq/processor.rb:124:in `block in dispatch'
sidekiq-6.5.8/lib/sidekiq/job_logger.rb:39:in `prepare'
sidekiq-6.5.8/lib/sidekiq/processor.rb:123:in `dispatch'
sidekiq-6.5.8/lib/sidekiq/processor.rb:168:in `process'
sidekiq-6.5.8/lib/sidekiq/processor.rb:78:in `process_one'
sidekiq-6.5.8/lib/sidekiq/processor.rb:68:in `run'
sidekiq-6.5.8/lib/sidekiq/component.rb:8:in `watchdog'
sidekiq-6.5.8/lib/sidekiq/component.rb:17:in `block in safe_thread'
Env
hostname gaoa-discourse-app
process_id 11140
application_version ea4f7fb660cb4cb5cba3763e9a28352123d39591
current_db default
current_hostname forum.[xxx].com
job Jobs::CriticalUserEmail
problem_db default
time 8:54 am
opts type account_suspended
user_id 3919
user_history_id 41800
current_site_id default
Edit to add sidekiq status:
Hi @omarfilip,
I don’t have a solution for you, but I wanted to confirm I was able to replicate this experience on an installation of Discourse that does not have many plugins.
Steps taken to replicate:
  1. Select a user from /admin/users/list/active and manually suspend with the suspend button.
  1. Add text in the “Email message” field.
  1. Click the suspend button and confirm the user is now suspended.
Result: No email is sent, and there is a Job Exception in the error logs.
Message (3 copies reported)
Job exception: undefined method `topic' for nil:NilClass
Backtrace
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rails_multisite-4.0.1/lib/rails_multisite/connection_management.rb:80:in `with_connection'
Hi @omarfilip,
Did any of your suspension emails ever send?
The emails related to my test suspensions were sent 2023-04-09T10:10:00Z, with no further action from me, but new suspensions are still failing with the same error.
Thanks for the report and the repro @omarfilip and @southpaw :+1:
Someone has been assigned to look into it and should hopefully have some answers soon. :crossed_fingers: :slight_smile:
Same issue with new suspensions - they just pile into the failed queue.
Note, this is assigned out internally, we hope to work on a fix in the upcoming few days.
This should be fixed by: :+1:
https://github.com/discourse/discourse/pull/21054
Thanks. That cleared the stuck jobs in sidekiq right away. :+1:
