SVG 上传因 CR/LF 失败,改为 LF 后正常
After reading
SVG corruption on download of local images
It looks like the process of uploading is breaking the file, somehow. You can run a diff on the original I found on wikipedia: https://upload.wikimedia.org/wikipedia/en/d/d2/Stitch_(Lilo_%26_Stitch).svg
Doing so, it looks like removing linebreaks somehow busted this? The data appears the same, but everything has been moved to a single line rather than being multi-line? Can anyone verify my analysis is correct here?
In testing this idea, copied a simple SVG created with GraphViz on Windows that contained CR (Carriage Return) and LF (Line Feed) and tried an upload. Received the error dialog:
Sorry, but we couldn’t determine the size of the image. Maybe your image is corrupted?
Then using a text editor (NotePad++) used the menu option View -> Show Symbol -> Show All Characters to see the line end characters; they were CR/LF. Changed them to LF, saved the file and uploaded. :smiley:
ast_transformation_derivative_constant_after%20(linux)
What exactly are you reporting? The other topic you referenced is very old and out of date so I have deleted it.
That uploading an SVG that contains CR/LF will fail with error message. However uploading an SVG that has the CR/LF converted to LF will work.
In other words, if a user sees the error message:
How are they to know that one of the problems is that they should change the CR/LF to LF
or another option is that
discourse should modify the security scanner/whistleblower to allow CR/LF as valid. :smiley:
2 个赞
