Hey there, it’s your favourite bug finder, support bothering user.
I was testing the restore this afternoon and two times out of two, ended up with this:
ERROR: could not extend file "base/16384/3294755": wrote only 4096 of 8192 bytes at block 43985
HINT: Check free disk space.
EXCEPTION: psql failed: HINT: Check free disk space.
/var/www/discourse/lib/backup_restore/database_restorer.rb:92:in `restore_dump'
/var/www/discourse/lib/backup_restore/database_restorer.rb:26:in `restore'
/var/www/discourse/lib/backup_restore/restorer.rb:51:in `run'
script/discourse:149:in `restore'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/thor-1.2.2/lib/thor/command.rb:27:in `run'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/thor-1.2.2/lib/thor/invocation.rb:127:in `invoke_command'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/thor-1.2.2/lib/thor.rb:392:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/thor-1.2.2/lib/thor/base.rb:485:in `start'
script/discourse:290:in `<top (required)>'
/usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.13/lib/bundler/cli/exec.rb:58:in `load'
/usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.13/lib/bundler/cli/exec.rb:58:in `kernel_load'
/usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.13/lib/bundler/cli/exec.rb:23:in `run'
/usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.13/lib/bundler/cli.rb:492:in `exec'
/usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.13/lib/bundler/vendor/thor/lib/thor/command.rb:27:in `run'
/usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.13/lib/bundler/vendor/thor/lib/thor/invocation.rb:127:in `invoke_command'
/usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.13/lib/bundler/vendor/thor/lib/thor.rb:392:in `dispatch'
/usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.13/lib/bundler/cli.rb:34:in `dispatch'
/usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.13/lib/bundler/vendor/thor/lib/thor/base.rb:485:in `start'
/usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.13/lib/bundler/cli.rb:28:in `start'
/usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.13/exe/bundle:45:in `block in <top (required)>'
/usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.13/lib/bundler/friendly_errors.rb:117:in `with_friendly_errors'
/usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.13/exe/bundle:33:in `<top (required)>'
Trying to rollback...
Rolling back...
Cleaning stuff up...
Dropping functions from the discourse_functions schema...
Removing tmp '/var/www/discourse/tmp/restores/default/2023-08-19-145440' directory...
Unpausing sidekiq...
Marking restore as finished...
Notifying 'system' of the end of the restore...
Finished!
[FAILED]
Restore done.
Special mention to the
Finished!
[FAILED]
Restore done.
That made me kinda laugh ![]()
I’d say that this is really bad, on a scale to “not that bad” to “incredibly bad”.
I restored in a staging environment (a separated VMs we use for testing and messing about) after doing a clean:
launcher stop apprm -rf /var/discourse/sharedlauncher rebuild app
The restore I tried is the last one created by the automated restore and backed up in an S3.
Then downloaded via the link provided via mail and restored using this guide:
The backup was 10GB. On the VM there were roughly 110GB free when I started the restore.
Edit: Discourse version 3.2.0.beta1-dev (fbf7b106cc)
