The topic progress indicator
A discussion is taking place about the topic progress indicator in Discourse. anon20391312 likes the infinite scrolling feature but thinks the progress display can be improved. They share an example of a different forum software that uses a scrollbar-like progress tracker, allowing users to scroll and load posts by dragging the indicator. codinghorror mentions that changes to the right gutter are planned for release 1.5, and later updates that it has been pushed to 1.6, with an early version now live.
Let me start with saying that I quite like the infinite scrolling-mode. It’s easy to read through an entire discussion (yes, I sometimes do that) without having to click “Next page” even once. However, I do think there is some room for improvement to how the ‘progress’ is displayed to the end user.
To the bottom of the page you can find this widget, for which I think there is some room for improvement:
I ran across a ddifferent forum software package, where they have also implemented the infinite scrolling feature. They have also created a topic progress tracker, but theirs somewhat resembles a more familiar concept: the scrollbar. Their implementation looks as follows:
Go here to give it a go. By grabbing the progress indicator and dragging it up or down, the forum scrolls up or down and loads the associated posts. Because of its vertical orientation, this feels liek a better combination of scrollbars and infinite scrolling than how Discourse currently handles it.
Yes, this is listed on the 1.5 plan if you visit the releases category. I have never been happy with the right gutter in general so there are changes coming in that area.
Slipped to 1.6 but early version is now live.
