"There are 84 replies with an estimated read time of 0 minutes."
סיכום מבוסס בינה מלאכותית
A user uwe_keim reported that a forum thread containing only developer memes showed an estimated read time of 0 minutes — despite 84 replies — which felt inaccurate since viewing images takes time. He suggested setting a minimum read time of 1 minute for such cases. codinghorror and sam agreed, with sam proposing a minimum of 2 seconds. zogstrip and zogstrip tagged team members to address the issue. uwe_keim further suggested factoring in image count or size, while Yuun humorously noted ‘a picture is worth a thousand words’. codinghorror responded with a GIF. Finally, nbianca implemented a fix: replacing floor with ceil to ensure a minimum of 1 minute, and introduced a baseline of 4 seconds per post (based on time to view an image or read a short post). The updated algorithm now estimates 6 minutes for the original thread — which matched the actual reading time — and the fix is merged via GitHub PR #7842.
I have a forum post where I simply collect images of developer memes:
The summary below the introduction post says (in German):
Es gibt 84 Antworten mit einer geschätzten Lesezeit von 0 Minuten.
This translates to English as:
In my opinion, it will take more than zero minutes to “read” (i.e. look at) the images.
Suggestion
My suggestion would be to have a minimum value of 1 (instead of 0) for the estimated reading time to cover edge cases like mine with actually zero text but only images.
This is rather funny :framed_picture:
Yeah I agree, I don’t think any post can be read in less than say 2 seconds. So we should start there with 2 seconds as a minimum.
@maja can you add that to your list?
I dont’ know how your algorithm calculates the time. I guess based on the number of characters and/or words.
If I’m correct here, how about adding a factor for every image, too?
Maybe even different factors for small/medium/large images?
Well, a picture is worth a thousand words, so
@nbianca can you add that to your list?
I replaced the floor with a ceil operation to ensure that we always show at least “1 minute”.
Also, it will try to choose the maximum between the old formula (word count / read_time_word_count) and the minimum reading time (4 seconds per post; 4 because that is how long it takes me to read a short post or see an image and scroll to the next post). :hourglass:
For that topic, the formula gives 6 minutes. I managed to read the topic in a little under 6 minutes, so I’d say it works fine. :nerd_face:
https://github.com/discourse/discourse/pull/7842
