We are planning to use user field for storing the text which is bigger then 2,048.
Is there any chance to have it configurable as proposed here -
https://meta.discourse.org/t/user-field-lengths-are-unbounded/25450/5
many thanks in advance
The said user configurable limits would probably be between 1 - 2048 and not more. The user-field inputs doesn’t provide good UX to input larger texts anyway.
When using larger inputs you can store in a custom_field and use the d-editor to let users input largers texts.
thanks you, the question is exactly on custom user fields. We want to store some content programmatically is one custom user field per user. the current limit is 2048, thats exactly that we want to overcome for that field (if possible). Please advice. thanks
You can use the PluginStore for those fields.
Many thanks. thats might be proper solution for us.
This topic was automatically closed after 2728 days. New replies are no longer allowed.
