Move topics from one Discourse instance to another
Need to move some stuff from one instance of Discourse to another?
There is a command line tool to export a topic, a set of topics, or an entire category, and another to import them in at the other end.
Topic Export/Import
  • one or more topics and their replies
  • the users who posted in the topic
Category Export/Import
  • the category and all its subcategories
  • its security settings
  • custom groups mentioned in the security settings
    • :warning: if any of the groups have ‘membership requests’ enabled, it will crash. Turn this off before the export
  • all topics and posts in the category and subcategories
  • all users who posted, and assigns them to the groups
Begin: Identify the IDs
First, identify the ID(s) of the =Export= that you wish to export. You’ll find this at the end of the URL used to access it.
  • https://meta.discourse.org/t/how-to-contribute-to-discourse/53797
  • https://meta.discourse.org/t/how-to-contribute-to-discourse/53797/12
    (in this case you are in the middle of a topic - grab the first number)
  • https://meta.discourse.org/c/howto/faq/4
Category or Topic ID(s)
Multiple topics
You can select more than one topic by adding IDs separated by a space; this works in the field above (I don’t think that this works for categories though):
  • 53797 200943 124096
Run the Export Script
The tool can be run as a root user inside the container:
cd /var/discourse
./launcher enter app
Run this command:
discourse export_=Export= =ID=
The output should look something like this:
Starting export of =Export=…
Where are the new users all coming from?
Export saved to =Export=-export-2021-08-27-015437.json
Done
Move the Exported File
The exported .json file needs to be moved from the inside of the application container where you did the export to the inside of the container of the receiving instance. This takes a few steps.
Copy it to the ‘outside’
Exit the container if you haven’t already
exit
You should now have a prompt like this:
root@yourserver:/var/discourse
Use docker to copy the file out of the container (you can’t move it I don’t think)
docker cp app:/var/www/discourse/=FileName= .
Move it to the other instance
This is beyond the scope of this guide, but this might help you get there:
Copy it into the container in the receiving instance
SSH into your receiving instance as root and get to the Discourse directory:
cd /var/discourse
Use docker once again to copy the file into the other container
docker cp =FileName= app:/var/www/discourse
Import the Content
Enter the container in the receiving instance:
Run the import script
discourse import_=Export= =FileName=
:cake: Done!
You might need to tidy up some loose ends, but hopefully, it should all be done.
Advanced Tips
Missing Ruby Gem
When doing a complex category import, my instance was missing the ‘Listen’ Ruby.
This was solved by doing this: (using the Discourse user inside the container)
su discourse
bundle config --delete without
bundle install
exit
exit
This broke the rails console, necessitating a rebuild afterwards
./launcher rebuild app
Multisite
In a multisite environment, use the RAILS_DB env variable.
RAILS_DB=xxxmoves discourse export_=Export= =ID=
RAILS_DB=dancerehab discourse import_=Export= =FileName=
Please report bugs in the Contribute > Bug category, and request enhancements in the Contribute > Feature category.
Related Topics
Last Reviewed by @SaraDev on 2022-07-13T00:00:00Z
UI: Topic and Category Export/Import
CLI command to migrate a single category
Moving topics between sites?
Category/Topic export fails with error "database "discourse_development" does not exist"
Easiest way to export a single topic?
Saving a Conversation
How to export user data from a category on a hosted site
Import CSV User Activity from one Discourse to Another
How use API to convert topic in discourse1.com to discourse2.com
Can sub-forums of the same instance split up and move to new independent servers (or discourse instances)?
Help migrating category from one instance to another without admin on the source instance
I wonder how to add hundreds of users into a group? Is there any api?
How to download Comments and Topics
Adding default sets of topics, categories and users to a new Discourse
Can we combine 2 separate discourse sites?
Tracking and resolving a schema drift cause
Merge two Discourse forums into one
Moving topics from a forum on one website to a forum on another website
Transfer topics between forums?
Forum Aquisition
Transfering inbox group messages to another instance?
Imported categories are not in parent category
Copy categories / topics
Downloading Content
Selective backups skipping settings and config
Test driving admin/moderation features
Add backup to existing Discourse instance
Merging two Discourse forums
Migrating vBulletin onto existing and live Discourse instance
Migrate topics from one discourse instance to another?
A system where people have to start at lesson 1, and cannot see the other lessons?
How to divide my community into 2 parts
Migrate user custom fields to another instance
Error Importing Categories from a Discourse Instance to Another
I’m about to have a crack at this again.
Is there an easy way to migrate the relevant uploads along with the Topics?
Not really. A thing that mostly works is if you get all of those uploads and paste the URL of the original in to any post on the site you’re moving to, then what should happen is that those uploads will get created with the same SHA and it Just Works.
So you’d do the thing that converts the stuff in the post to the URL to get those URLs. (I can never quite remember how to do that, so I have to figure it out every time).
Hmmm - I remain a bit confused by that. Are you saying that this will work?
  1. Grab all of the upload files from the first site
    • how?
  2. Drop them into a single topic
  3. They will generate the same relative link as they had in the old site and magic!
Or did you mean this?
  1. Grab all of the absolute URLs in your categories of interest from the old site
  2. Paste these into a Topic
  3. They will all be downloaded to the new site with the same SHA and the existing links will all work like magic
Or something else entirely?
I think either of those should work. However you can get those images to the new site, they should generate the same sha so that will magically make the existing links in the topics work.
Maybe you could do something like
cat_id=123
Topic.where(category_id: cat_id).each do| t|
  Post.where(topic_id: t.id) do |p|
      p.cooked.match(image url)....
         puts(the match)
And I think if you do that and paste those links into a post anywhere on your site it should download all of those images to local and make the same sha, so then those links. You can try a couple by hand to see.
It’s the middle of the night. Your mileage may vary.
Hello, I’m not sure if this tutorial is what I want to do, but raise the question here.
If I install discourse on a server, but due to growth I need to migrate to a more powerful one, are these the steps?
What happens, for example, with the backup option? Can’t I do it, install Discourse on another server and then restore the backup copy of the other instance from that option?
I await your clarification, since I want to know how to migrate when I need to and not lose the work I have been doing recently.
No. To move to a bigger server a simple backup and restore is all that’s needed. You can also Move a Discourse site to another VPS with rsync
I’ve been wanting to solve the upload migration problem for just about forever, and now with LLM help have gotten there. Sharing my notes for those who follow! Jay’s post above contained the special sauce needed to get me started so thanks for that.
My first pass at this worked exactly as Jay predicted. If you create a list of urls to the images on the site you are moving from and paste that into a post on your new site, they will be downloaded. Download remote images to local must be enabled for this to work.
My LLM created a script for that which I’ll share here for future travelers.
Summary
Run this in the rails console:
topic = Topic.find(=TOPIC_ID=)
posts = Post.where(topic_id: topic.id)
urls = []
posts.each do |p|
  UploadReference.where(target: p).each do |ref|
    urls << "=SOURCE_URL=#{ref.upload.url}"
puts urls.uniq.join("\n")
puts "\nTotal: #{urls.uniq.count} upload(s)"
:bulb: Moving a whole category instead? Replace the first two lines with:
topic_ids = Topic.where(category_id: =TOPIC_ID=).pluck(:id)
posts = Post.where(topic_id: topic_ids)
In this case =TOPIC_ID= is your category ID, found at the end of its URL in Admin → Categories.
However for me that ended up not being good enough because I also have PDFs which do not get downloaded to local automatically.
So I had my LLM write me a python script to migrate the uploads. It works quite well so happy to share it as well. If you’d like to try it or have feedback, here’s the repo: tobias/discourse-upload-migrator - Digitally Sovereign Forgejo: Digitally Sovereign, for the win!
I also had my LLM write me a more complete runbook on moving topics or categories, which is up on my discourse: https://digitallysovereign.org/t/move-topics-or-categories-between-discourse-instances/742?u=tobias
