Tópico com japonês na URL não redireciona se a URL não corresponder perfeitamente
Does that mean that when people switch from encoded to ascii it doesn’t regenerate the slugs? If so it seems like the one time process you wrote to clear the slugs wouldn’t work for those cases.
1 curtida
Hello,
The pull did not fix the issue completely. If the slug contains a + sign, it will show the 400 error.
To confirm this, I have switched back to “None” for slug generation, edited the title and removed the + sign from title and switched back to “encoded” it fixed the 400 error.
The scenario is when a title includes a plus sign, it returns 400 error. (There could be other characters that could lead to this. I only tested the + sign)
Thank you
5 curtidas
Is that on a topic slug or in a category slug?
4 curtidas
A topic slug. Didn’t try on the categories.
3 curtidas
The encoded slug generator strips all + signs so I have no idea how you get that:
Just tested locally and they are removed just fine for me.
3 curtidas
Perhaps the scenario is different on your local.
My website language is Persian. Can you switch to Persian and then test?
To duplicate this, create a topic with the following subject:
Iranian cats + belong to a good breed
My slug turns into an unreadable format and returns a 400 error:
https://domain.ltd/t/%D8%A7%DA%A9%D8%A7%D9%86%D8%AA-%D9%BE%D8%B1%D9%85%DB%8C%D9%88%D9%85-%D9%88%D8%A8-%D8%B3%D8%A7%DB%8C%D8%AA-%D9%85%D9%88%D8%B2-%D8%B1%D8%A7%DB%8C%DA%AF%D8%A7%D9%86-%D8%A7%D8%B4%D8%AA%D8%B1%D8%A7%DA%A9-%D8%B4%D8%AE%D8%B5%DB%8C-%D8%A8%D8%B1%D8%A7%DB%8C-%DA%A/2067/40
2 curtidas
Only you are aren’t using the “og” + but a different persian symbol that looks like it? Can you share a string that repros the problem?
3 curtidas
I edited my previous reply. Just to confirm it is a + .
2 curtidas
That is weird, for me the slug turns into
%DA%AF%D8%B1%D8%A8%D9%87-%D9%87%D8%A7%DB%8C-%D8%A7%DB%8C%D8%B1%D8%A7%D9%86%DB%8C-%D8%A7%D8%B2-%D9%86%DA%98%D8%A7%D8%AF-%D8%AE%D9%88%D8%A8%DB%8C-%D8%A8%D8%B1%D8%AE%D9%88%D8%B1%D8%AF%D8%A7%D8%B1-%D9%87%D8%B3%D8%AA%D9%86%D8%AF
Are you sure you are running latest and refreshed the page?
2 curtidas
I am running the latest version.
I am confused now. I created a new topic with the same condition as the topic with corrupt slug. It works just fine. Just like you stated, probably it isn’t the + that is causing the problem.
Please allow me sometime to install a dummy and make some tests. I will update this topic with more information.
Thank you
2 curtidas
Did you get that URL from the share button? It was double encoding and I just fixed that on the latest merge.
2 curtidas
Check this screencast.
3 curtidas
Oh I see the problem. It only happens with slugs who are above 255 chars and only in 66% of the cases. I will work in a fix tomorrow.
12 curtidas
Happens with us too:
eg: Γνώμη για αγορά μπουζουκιού μέσω ίντερνετ και εκτίμηση - #2 από nikos_politis - Μουσικά όργανα - Ρεμπέτικο Φόρουμ
Strangely, it only happens when you hit the topic from the “latest” list. When you link to it from another topic, it works just fine.
The full link:
https://rembetiko.gr/t/%CE%B3%CE%BD%CF%89%CE%BC%CE%B7-%CE%B3%CE%B9%CE%B1-%CE%B1%CE%B3%CE%BF%CF%81%CE%B1-%CE%BC%CF%80%CE%BF%CF%85%CE%B6%CE%BF%CF%85%CE%BA%CE%B9%CE%BF%CF%85-%CE%BC%CE%B5%CF%83%CF%89-%CE%B9%CE%BD%CF%84%CE%B5%CF%81%CE%BD%CE%B5%CF%84-%CE%BA%CE%B1%CE%B9-%CE%B5%CE%BA%C/38511/2
Same thing, that slug is over 255 chars.
4 curtidas
While investigating, I found some categories that can’t load at all.
I found that we get these kind of errors:
URIError: URI malformed
    at decodeURIComponent (<anonymous>)
    at a (https://rembetiko.gr/assets/ember_jquery-7dfac344d893a6c10c016353b994db2c6f42af630322ea6da3399c220fcc50ed.js:16:31208)
    at Array.map (<anonymous>)
    at o (https://rembetiko.gr/assets/ember_jquery-7dfac344d893a6c10c016353b994db2c6f42af630322ea6da3399c220fcc50ed.js:16:31136)
    at P.recognize (https://rembetiko.gr/assets/ember_jquery-7dfac344d893a6c10c016353b994db2c6f42af630322ea6da3399c220fcc50ed.js:17:5729)
    at t.applyToState (https://rembetiko.gr/assets/ember_jquery-7dfac344d893a6c10c016353b994db2c6f42af630322ea6da3399c220fcc50ed.js:17:22054)
    at u.n.getTransitionByIntent (https://rembetiko.gr/assets/ember_jquery-7dfac344d893a6c10c016353b994db2c6f42af630322ea6da3399c220fcc50ed.js:17:24304)
    at u.n.transitionByIntent (https://rembetiko.gr/assets/ember_jquery-7dfac344d893a6c10c016353b994db2c6f42af630322ea6da3399c220fcc50ed.js:17:23609)
    at u.n.doTransition (https://rembetiko.gr/assets/ember_jquery-7dfac344d893a6c10c016353b994db2c6f42af630322ea6da3399c220fcc50ed.js:17:25611)
    at u.n.transitionTo (https://rembetiko.gr/assets/ember_jquery-7dfac344d893a6c10c016353b994db2c6f42af630322ea6da3399c220fcc50ed.js:17:30132)
TypeError: Cannot read property 'responseJSON' of undefined
    at n.error (https://rembetiko.gr/assets/application-5d69c42124908eb6b41549efae9db9b1df26741f3a45075c6bfd603bb5267a42.js:71:604)
    at n.C (https://rembetiko.gr/assets/ember_jquery-7dfac344d893a6c10c016353b994db2c6f42af630322ea6da3399c220fcc50ed.js:8:17733)
    at u.c.triggerEvent (https://rembetiko.gr/assets/ember_jquery-7dfac344d893a6c10c016353b994db2c6f42af630322ea6da3399c220fcc50ed.js:8:21275)
    at e.t.trigger (https://rembetiko.gr/assets/ember_jquery-7dfac344d893a6c10c016353b994db2c6f42af630322ea6da3399c220fcc50ed.js:17:13392)
    at u.c.transitionDidError (https://rembetiko.gr/assets/ember_jquery-7dfac344d893a6c10c016353b994db2c6f42af630322ea6da3399c220fcc50ed.js:8:21548)
    at https://rembetiko.gr/assets/ember_jquery-7dfac344d893a6c10c016353b994db2c6f42af630322ea6da3399c220fcc50ed.js:17:11836
    at f (https://rembetiko.gr/assets/ember_jquery-7dfac344d893a6c10c016353b994db2c6f42af630322ea6da3399c220fcc50ed.js:18:1126)
    at T (https://rembetiko.gr/assets/ember_jquery-7dfac344d893a6c10c016353b994db2c6f42af630322ea6da3399c220fcc50ed.js:18:2503)
    at E (https://rembetiko.gr/assets/ember_jquery-7dfac344d893a6c10c016353b994db2c6f42af630322ea6da3399c220fcc50ed.js:18:2402)
    at y (https://rembetiko.gr/assets/ember_jquery-7dfac344d893a6c10c016353b994db2c6f42af630322ea6da3399c220fcc50ed.js:18:1896)
Can those be related?
(you can check for yourself here: https://rembetiko.gr/c/άλλα-θέματα/μικρές-αγγελίες)
2 curtidas
@Arta_S and @chrispanag two more fixes incoming, one for long titles and the other for subcategories.
and
8 curtidas
After upgrading, we still get this error :confused:
2 curtidas
In this case you will need to rebake the slugs, please try:
cd /var/discourse
./launcher enter app
rails c
Topic.update_all(slug: nil)
exit
exit
exit
6 curtidas
Two days ago from last update I have two problems:
1: 400 Bad Request URL in some topic
2: timeline disappeared in some topic
host Discourse 'standard-plan"
Can you Help Me
sorry i don’t write English well
2 curtidas
